should this happen after i install sportlines?
Old Mar 16, 2012 | 05:52 PM
ChargedxSSx's Avatar
my steering wheel sits about 15 degrees to the right ... i havent got an alignment but i have an appointment on mendsaday .. will it be fixed after that?
p.s. who ever started the rumor of needing a spring compressor to take apart the front struts ... is WRONG ...
Old Mar 16, 2012 | 06:07 PM
Sox-Fan's Avatar
Got Brakes?
A proper wheel alignment should straighten the wheel.
Do you NEED a spring compressor? Maybe, maybe not. Will it make the job easier? yes. Will it help prevent injury? yes.
Old Mar 16, 2012 | 06:09 PM
thanks buddy. and i just took the strut out ... took the top off and it just popped off .. very little pressure ... but yes ... installation would have been easier with them
thanks again
Old Mar 16, 2012 | 06:10 PM
TommyP's Avatar
AWD > FWD
No that's not normal, though an alignment will fix that. I can't believe you changed the alignment that much with just a spring change, you must have messed with way more than you needed to.
Old Mar 16, 2012 | 06:19 PM
BPacak's Avatar
Vtec Rep
Seems legit
Old Mar 16, 2012 | 06:23 PM
05Slowline's Avatar
tell yourself that we'll wait for your pics with one eye and no teeth
Old Mar 16, 2012 | 06:33 PM
cobalt_sport08's Avatar
Yeah DEF not normal I just installed mine last weekend and have had no problems with it pulling or anything..(WTF did you do?! )
but I'm still going to get an alignment after spring break.
and you had to have compressors to get the new springs on the strut...?
Old Mar 16, 2012 | 06:38 PM
zerosk8ter83's Avatar
theres no way I couldve gotten my spring back on the strut without the compressor
Old Mar 16, 2012 | 06:42 PM
there isnt any pull or anything ... just a little camber ... and the alignment is off ... it was off a little before i did it tho ... there isnt too much u can do wrong .. its only 2 bolts and a sway bar link ...
and i did it fine with no compressor ... just took it apart and when i put it together ... i pushed down on the top while my buddy screwed the stru top back together ..
Old Mar 16, 2012 | 06:45 PM
and arent the SC struts way cheaper and weaker than the TC
yeah I know ha that's why i was wondering.... and then y'all must be damn strong
Old Mar 16, 2012 | 06:58 PM
nizzle's Avatar
Yea you need to have an alignment done after raising or lowering your car
Old Mar 16, 2012 | 07:02 PM
hoonestly man it wasnt that bad ... at all ...
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
