SS/SC spring problem
I have a LT which i installed SS/SC springs on. I had the fronts installed by a stop, and i did the rears myself. When the fronts were installed i was watching, and i saw the springs were properly seated. However, its been a while and the springs have settled, but I have found that the front of the car sits higher than the rear. I mesured from the front and back of the sideskirt, and indeed the front is higher.
So, my question is what could be causing this? Any help would be appeciated
Josh
Josh
Well the difference is probably about a half inch, which is alot considering the back is supposed to sit higher than the rear. And i put the seats back on, I installed the new springs exactly the same as the old ones were.
