Steering Rack Spacer
Old Nov 8, 2010 | 11:15 PM
08SStc's Avatar
just a note about installing the spacers. to make your life much easer. remove one bolt than just loosin the second bolt but dont remove it. it will keep the rack were it should be and you wont have to try to align it while installing the spacer then trying to thread the bolt. I did this on jack stands on my back. this helps to save a little headache.
Old Nov 8, 2010 | 11:33 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by CobaltVenomSS
AHHHHHH!!!! i just want to know what to buy
idk if i need endlinks axles or what
There are a variety of things that could be wrong. Jack your car up, remove a wheel, and check your Endlinks for play. Generally, the endlinks only clank around when going over bumps and such though. Check your axles for play. Does it do it when you come to a stop at a light? And/Or when you accelerate from a stop light/sign?
Old Nov 9, 2010 | 07:32 AM
Wangspeed's Avatar
The other thing you need to do is to jack up the entire front to do this. If you leave one front wheel on the ground, it's going to throw your alignment out of whack from left to right. The spacers will slightly change your toe. I don't recall which way off the top of my head, I'd have to look under the car.
Old Nov 9, 2010 | 08:06 AM
RoadconeTuning's Avatar
Originally Posted by Wangspeed
I don't think the ackerman angle has changed by adding the rack spacers. To do that, you'd probably have to relocate the rack or tie rods ends.
what do you think the spacers do lol... it changes the rack location, when you lower the car you're lowering the steering rack while keeping the tie rods in relatively the same location, when you add spacers you are bringing them back in line...
so, it changes the ackerman angle back to a more stock-ish figure
heres the mustang stuff about it... and unless these spacers do something differnet than the offset bushings did for mustangs... it accomplishes the same thing
Installation of Maximum Motorsports Aluminum Steering Rack Bushings
DazeCars, Suspension 101
Old Nov 9, 2010 | 11:27 AM
08SStc's Avatar
good call. forgot to mention that.
Old Nov 9, 2010 | 02:16 PM
Wangspeed's Avatar
You are confusing bump steer and macpherson camber angle changes with ackerman angle. The first link you provided even mentions that it's moving the rack rearwards. We're not changing ackerman on this car by moving the rack up and down, just bump steer characteristics. We would have to move the rack or ball joints back or forward.
Old Nov 9, 2010 | 02:19 PM
ChevyRockstar's Avatar
i just dont know what to replace on my car... axles or what
intermedate shaft, my car has the same problem kyle.
Old Nov 29, 2010 | 09:53 AM
CobaltVenomSS's Avatar
coming to a stop is normal...but when going over bumps theres a knocking noise thats very noticable... and when i got wot or when i shift to 2nd normally i get a vibration... and when i do u-turns i get a clunking noise when i give it gas but if i let off it goes away
Old Dec 2, 2010 | 03:53 PM
averagewhiteboy's Avatar
Ordered from OTTP on the 19th, still not here. Not too excited seeing as how my Moog links came in two days.
Old Dec 2, 2010 | 04:10 PM
link to moog links??
Old Dec 2, 2010 | 07:15 PM
  #36
Josh@ottp's Avatar
I don't have an order for end links from the 19th. Get me your order number and I will check on it for you.
Old Dec 6, 2010 | 10:11 AM
  #37
Noooo.. I ordered a set of steering rack spacers from you guys at OTTP.. The Moog links I got from Rock Auto.. Still haven't received the spacers yet..
Old Mar 4, 2011 | 01:16 AM
  #38
BLue NoTe's Avatar
Yeah these were a lot of fun to install
Old Mar 4, 2011 | 01:21 AM
  #39
redcobalt07's Avatar
The rack spacers work with the stock tranmission mounts.
Old Mar 4, 2011 | 09:12 AM
  #40
Wangspeed's Avatar
Only the thin ones. I just installed thicker ones 8mm, but I couldn't have done it without the stage 1 rotated mounts.
Old Apr 19, 2011 | 06:59 PM
  #41
Gunney_07's Avatar
**** i just took every thing apart... wish this would be listed under the part description when purchasing.............
Old Apr 19, 2011 | 08:45 PM
  #42
JL-KA's Avatar
So where or how do you order the thin ones? I don't see that option on the OTTP site.
All it shows is the 4 lowering options: 0-.7, .8-1.3, 1.4-1.9, 2.0+
Is that only a problem with the SS or will I have that problem with my 2.2 with Pedders?
Old Apr 28, 2011 | 11:45 AM
  #43
Sweetsandman's Avatar
I'm installing my Pedders and rack spacers this upcoming Wednesday. The Pedders and Rack Spacers came as a package deal with a sale they were doing a while back...they are the .8-1.3 spacers. Are you saying I need upgraded tranny mounts to run the spacers?
Old Apr 28, 2011 | 12:52 PM
  #44
Gunney_07's Avatar
I had to.... I had pedder springs with ttr spacer and it wouldn't fit with the stock mount. So i ordered ttr s.t.o.p mounts
Old Apr 28, 2011 | 01:20 PM
  #45
Rodimus_Prime's Avatar
mine are 12mm thick for the 2.0 lowering, my concern however though is that the bolts are not nearly as threaded into the the subframe as what they were before, I dont want them coming undone and then having an accident caused because of it
Old Apr 28, 2011 | 01:23 PM
  #46
Josh@ottp's Avatar
The 2 smallest sizes of our spacers will fit on stock mounts for sure. The 3rd size may fit and the largest size won't fit without mounts. I should go update this....
Old Apr 28, 2011 | 01:24 PM
  #47
Awesome that first part is the category I fall into so that's great news!
Although, I'll probably order the tranny mount eventually anyways...just glad to hear I don't have to do it RIGHT now lol!
Old Apr 29, 2011 | 12:59 PM
  #48
JL-KA's Avatar
Sooooo....what do us 2.2's with Pedders do? Just live with the bumpsteer? Afaik the rotated mounts are for 2.0 only right?
Old Apr 29, 2011 | 01:03 PM
  #49
Get the rack spacers from ttr.
Old Apr 29, 2011 | 06:21 PM
  #50
JL-KA's Avatar
How thick are the different sizes? I'm told I need a 3/4" for a 2.2 on Pedders and it sounds like it will never fit and there are not rotated mounts for 2.2 to accommodated it.
Solaris99
28
Mar 15, 2017 01:22 PM
TedSS
26
Oct 10, 2015 04:30 PM
Tupp
Sep 30, 2015 08:18 PM
goaliemo
Sep 28, 2015 01:37 PM
