Update on Progress Springs!
Originally Posted by Dezod
I am fully aware of suspension dynamics, however if you want better handling than stock, it usually requires a more aggressive drop because most production cars have a significant amount of body roll. They are designed with minimal noise, disturbance, ride comfort and max clearence.
ahahahaha , now that is kinda funny
you dont need to lower the car to reduce body roll , granted a lower spring will help
stiffer springs , different shock/strut valving , larger anti sway bars
the lower you go the more you gotta re-engineer the whole suspension
You can add about .2" more for settling height.
Any drop more than an 1" will cause your factory shocks to wear much faster than normal. A simple Ingalls Front Kit with 2 degrees correction kit like this will be fine:
http://dezod.com/pd_ingalls_engineer..._kitcobalt.cfm
^^You will need 2 of these. 1 per front wheel.
These springs will give the car more of a race car feel, low, stuck to the ground and less roll than OEM.
ok sorry to bother everyone, but still dont understand here.. I HAVE A 06 SS/SC...i want the lowest drop i can get without bags or coil-overs..i just want lowering springs k.. now which brand will drop the lowest>>> thank u guys please everyones opinoin is welcomed
Originally Posted by BlackLS
I have a couple questions about these springs for you and I'm really interested in buying springs within the week.
1. Are these springs in stock now?
2. Are you still offering free shipping?
3. How much better will the car handle (I'm going to get the progress sway bar at the same time?)
4. How is the ride?
5. Do you have any pictures with the springs installed?
6. Do you offer free shipping on the sway bar?
I will be awaiting your answers because as of now I think these are the springs I will buy
4. How is the ride?
2.) Yes
3.) Yes it will help reduce body roll and offer far better more dynamic handling
4.) 20-30% more aggressive than stock
5.) No, I do not.
6.) Yes we do.
Lowering springs are more stiffer in spring rates because of less height travel in rebound and compression, so that is 1 in the same on your comment.
1.) No they are not. We flew through all of them in no time.
2.) Yes
5.) No, I do not.
6.) Yes we do.
2.) Yes
5.) No, I do not.
6.) Yes we do.
Thanks for the answers. Do you know when you will be getting these back in stock and if I order them now will they just be shipped when they come in?
I would say put the order in ASAP and get in line. I will call Progress Wednesday....
I am wondering why lowering more than 1 inch would have anything to do with how fast a shock would wear out. Unless there is rust on the shaft that would ruin the seals or you were bottoming out the shock, it shouldn't care how long the spring is.
Dennis
Dennis
[QUOTE=marzbarz]
The drop specs are as follows:
-2.0" in FR & -1.8" in RR
whats the ride hieght for the ss/sc 06 model
By the way I just put in my order for the springs and a sway bar
Hey BlackLS, go with eibach, you will like them. Not to mention, there's plenty of pics to see, so you know you'll like them. I'm sure Dezod can get the eibachs much quicker than a month.
DANRICKARD
Oct 1, 2015 12:08 AM
