YYZ springs
Old Aug 13, 2012 | 11:29 PM
  #276
Wangspeed's Avatar
Originally Posted by Omiotek
get camber bolts..... not sure if johns working on a camber plate still....
biggest thing you can look for is your tire wear. if your wearing to the outer edge you need more negative camber.
A few things about camber bolts. Turn the bolt so that the head is at the front. This is important because you need the lock washer to fully engage the cam lobe, which is not possible on the other side due to the bracket.
The other thing is that it should be torqued to 85 ftlbs.
Old Aug 13, 2012 | 11:37 PM
  #277
noorj's Avatar
Thanks guys, I'll be getting bolts soon I guess to figure out how much camber I'll want/get used to it for next season.
Old Aug 14, 2012 | 12:29 AM
  #278
Wangspeed's Avatar
Thanks for the very well written reply but a true "enthusiast" wouldn't be driving a cobalt, lol, so anyway a lot of people have something to prove and I just don't buy into it. I do however have a very large desire for some of your more useful parts (rotated mounts, braking)
CM is the only springs I would run out of the ones listed here, "enthusiasts" mention that they are too soft but they are near stock rates. How can that be a bad thing since the car was proven in the Nürburgring.
Thanks for making parts for our cars btw, you are respected for a reason.
You're not helping your case here. I picked this car to be my track car. I think I qualify as an enthusiast. I have long list of fun good handling cars that I've owned. I picked this one because it's a well engineered car that is a monster on track. I'm not the only one that realized this. There are plenty of folks running track and autox events in Cobalt SS. Fairly sure they are also enthusiasts. Some choose to participate on this forum. Others wisely avoid.
As far as springs rates go. Again not doing yourself any favors here. If you reduce the travel to the point where you bang off the bump stops all the time, then the springs are too soft, or you have reduced the amount of travel too much. I had this problem with the front Pedders, and couteracted by running a custom set of linear rate bump stops, which is an artificial attempt to up the spring rate.
If you need to slam your car more than 1" from the TC ride height, then these aren't the right springs for you. There are tons of cheap crappy options that will accomplish that. Enjoy them.
Old Aug 14, 2012 | 12:32 AM
  #279
Wangspeed's Avatar
lol I think warren has it....check with gloria lol
Yep. I have it. Ready to send it to the next person. Just let me know!
Old Aug 14, 2012 | 09:31 AM
  #280
AARON-SS-TC's Avatar
i have H&r sports right now, and they are way too soft. plus the rake is terrible, i am slammed in the front and 3 finger gap in the rear after 1 year and 15k miles.
Nobody has talked in comparison to the B&G springs. They seem to have better springs rates and they lower the car to slammed in the front and 1 finger gap in the rear which is perfect in my opinion.
Old Aug 14, 2012 | 09:39 AM
  #281
09sscalicobalt's Avatar
haha agreed car and drive voted 08-10 cobalt ss best bang for the buck under 25k and thats one of reasons i bought it and to be a cheap track car also so you sir not wang are an idiot lol
Old Aug 14, 2012 | 09:48 AM
  #282
Powell Race Parts's Avatar
ur springs look like this:
free length rear is 11.25
10.25 in compression 255 mm 100 lbs
7 1/4 in compression coils bound
free length front is 11.25
255 mm 10 100
185mm 7.25 compression 360 lbs
158mm 6.25 coil bound
Old Aug 14, 2012 | 10:33 AM
  #283
old news. One unfortunate characteristic of people is they tend to rubbish what went down before.
the current management at GM is not a lot different from prior to bankruptcy. Karl Strake fits into that category.
and regrettably, this forum has people who drive Cobalts and love to say what a pos it is. Which begs the question, why do you drive one, hang around here, just to say you hate your car and its a pos?
Old Aug 14, 2012 | 11:01 AM
  #284
255 mm 10 100
thanks for the info, but what is the comparison on the B&G springs?
Old Aug 14, 2012 | 11:03 AM
  #285
rivaladore's Avatar
Keep drinking the Kool Aid. Even GM thinks our cars are crap.
While driving a Cobalt, Karl Stracke, vice president of global vehicle engineering, was blunt: "Look at this car, it's horrible. How did this get through so many people."
https://www.cobaltss.net/forums/gene...rrible-215138/
I think he was talking about the base model not the ss
Old Aug 14, 2012 | 11:13 AM
  #286
Some ppl are never statisfied, they could have a supercar but would complain about not enough trunk space. The cobalt is a great car for the cost.
Explaining your springs more to some ppl is like beating a dead horse. There will be plenty of ppl that will enjoy your springs for what they are designed for.
Old Aug 14, 2012 | 11:24 AM
  #287
Huh? I said "UR SPRINGS LOOK LIKE THIS" not sure how I can make it clearer.
Old Aug 14, 2012 | 11:27 AM
  #288
Post #92
But let me throw in some information here. Nominal rates. As the manufacturing shot peening normalizes, YYZ may settle 1/8th to 1/4 inch, NO loss of rate.
StockTC FE5 springs: front. Linear. 158 lbs
Pedders: front. Linear. 139 lbs.
YYZ: front. Progressive. 138 lbs at the first 5.5 inches of travel to 265 at full compression
(1st load 762 lbs @6.4 inches/2nd load 993 lbs @5.5. inches.)
Rear YYZ are variable rate. Pedders are not.
Old Aug 14, 2012 | 11:45 AM
  #289
^^^ troof thank you
Old Aug 14, 2012 | 11:51 AM
  #290
sorry, thought you were talking about my h&r springs rather than the B&G i was wanting to get...
Old Aug 14, 2012 | 12:05 PM
  #291
Now its me that has to apologise. H&R are shown. B&G are similar, but lower therefore worse.
Old Aug 14, 2012 | 12:14 PM
  #292
user 72239's Avatar
I can see these springs are good for the track individual and im glad that someone is still making good parts for our platform.
Old Aug 14, 2012 | 01:12 PM
  #293
Omiotek's Avatar
b&g springs garbage....ive tested all of these....
Old Aug 14, 2012 | 01:17 PM
  #294
Omiotek's Avatar
i have to agree here..... i mean i have multiple cars that range ALL OVER. 2001 Subaru RS, 2009 Cobalt SS, 1996 Saleen mustang, 1994 Z28(drag car) 81 Z28....so i mean i dont see where im not an enthusiast.... ive toyed with them all and done a lot of things to them. the cobalts by far one of my favorite owned cars to the day. ive had 2 of them. one making 442whp 450 ftlbs and after the accident i now have a mostly stock one. amazing car on the track and it hangs with the pack of cars that normally runs which include gt500s, 5.0s, boss 302s, couple corvettes, rx7s, other cobalts and so forth. some of this could be due to drivers but the cars never failed me on the track and on the road. track toy and dd
Old Aug 14, 2012 | 01:42 PM
  #295
Really? Well, i appreciate the response...so i basically wouldnt be getting a better spring, just a better look than my H&R sports
Old Aug 14, 2012 | 05:29 PM
  #296
Vander Nars's Avatar
Ok now im just confused, few weeks ago pedders was the ****, everyone said they where awesome, so about a week ago I bought some, and now since john came out with his pedders are trash? are pedders still a good performance spring or not? I understand johns springs are better for performance but it seems like everyone is now saying pedders are trash.
Old Aug 14, 2012 | 05:51 PM
  #297
BLue NoTe's Avatar
Yes, my car handled very well with Pedders. The big issue people had was that for their ride height they were too soft and it caused them to hit the bumpstops. That caused ride issues and apparently on wangspeeds car damage to his twist beam bushing and a bent shock, again since they were too soft for their ride height. I've never heard of a broken set of Pedders but they do rust, John says these hyperco made springs will not
They WERE the best option, the only performance option. Not anymore
Old Aug 14, 2012 | 06:17 PM
  #298
well I dont do any autocross or **** like that, im hit the 1/4 track a few times once im done with my setup but outside of that I just do a lil street racing and hitting corners and **** so I just want something that is focused on performance for the street with good looks, im guessing pedders will be more then enough for that?
Old Aug 14, 2012 | 09:44 PM
  #299
These should ride better than pedders since the rate is not linear, and the price point is fairly close, along with ride height (if I remember correctly, check back in the #60ish posts there is some photos of pedders then yyz). Not to mention John stands behind his work and if you have issues he will fix the problem and replace the part.
Old Aug 14, 2012 | 10:14 PM
  #300
Wangspeed's Avatar
I mentioned on the forum that they weren't very good if you push them. No one listened. Bugged John privately about it, til he did something to fix it
