P0300 - misfire on E85 LE5
Hey guys, so I recently swapped to 60's and E85 in preparation for the turbo I'm putting on. I spent a solid week getting the tune down good but now I'm getting a random misfire code. I'm thinking my injector settings might be off a little (they were given to me by a friend with a similar setup). I changed plugs and it still persists but I'm pretty sure my the logs it is only at idle. Any ideas?
The injector size depends on how much air he plans on pushing.
Do you have a return style fuel system installed? (Pretty sure the fueling was the same as the l61 stock returnless) could also try bumping the idle up 100rpm and see if it settles out
Sean Cummings
Mar 9, 2018 12:26 AM
Macgyver2484
Sep 2, 2015 05:44 PM
