Tuning MAF
See where I'm going here? You may want to either pay someone who knows their way around hpt to do this for you or pull up a comfy chair and do some serious reading on the hpt forums. There's a lot of good stuff to learn on there so just read up a bit before you get too crazy.
There even more to it than this than what typed, but this is basically the cliff notes version of what needs to be done. I hope this helps you a bit, or at least gets you in the right direction.
it does help. Alot i have a tuner but i keep getting p1101 and i dont know why i heard that you have to recalibrate for the larger maf housing. i have replaced the maf three times the o2 sensors and everything possible. Im lost at this point i get fuel cut or spark blow out it seems as well with it only when p1101 comes on
Oh yeah, I forgot you mentioned that.. lol..
here are the steps from GM's service site that are points to check when this code is set
• A restricted or collapsed air intake duct
• A misaligned or damaged air intake duct
• A dirty or deteriorating air filter element
• Any objects blocking the air inlet probe of the mass air flow (MAF)/intake air temperature (IAT) sensor
• Any contamination or debris on the sensing elements in the probe of the MAF/IAT sensor
• Any water intrusion in the induction system
• Any vacuum leak downstream of the MAF/IAT sensor
• An intake manifold leak
• A supercharger inlet pressure (SCIP) sensor seal that is missing or damaged
• A manifold absolute pressure (MAP) sensor seal that is missing or damaged
• A stuck supercharger bypass valve--Refer to Boost Control System Diagnosis.
• A skewed or stuck engine coolant temperature (ECT) or IAT sensor--Refer to Temperature Versus Resistance.
• Any type of restriction in the exhaust system--Refer to Restricted Exhaust.
also check to make sure your barometer is reading correctly as well in hpt
same as yours but its prob a foot where the maf is
idk i getting weird **** maybe its leaking at the intake idk ill have to do a pressure check
Last edited by firefighter404; May 23, 2012 at 08:00 PM. Reason: Automerged Doublepost
Did you put the rtv around the maf housing or gasket? How did you do it? Im worried about getting it on the sensor. I have had nothing but problems since I changed my maf, the car is now undrivable and stuck at work. When I bought it it had an open airbox with no filter and maf was unplugged. I decided to get cia until I can replace stock airbox, I ordered maf and left it unplugged until the maf arrived. I then changed the maf at work and it hasnt ran right since. Tried unplugging it again it still wouldn't run right. It has since rained so I know if its wet it could cause this but it didn't look wet, I tried unplugging battery for 15 mins and haven't found any leaks in intake and like I said it ran fine until I changed maf, i was told maf had to be AC Delco for these cars so i ordered one it will be here tomorrow but now I'm wondering if it's not leaking at housing? Would it cause horrible air fuel issues?
