Tuning MAF
Old May 22, 2012 | 01:43 AM
firefighter404's Avatar
Tuning MAF
Has anybody tuned with zzps 3inch MAF housing, if you have, have you ran into issues with code p1101. And did you have to recalibrate for the larger housing.
Old May 22, 2012 | 08:28 AM
hhrfreek's Avatar
You'll likely throw a lean code eventually too. You should tune the maf to the larger housing.
Old May 22, 2012 | 11:05 AM
what should it be recalibrated to or what process do you have to do to calculate it
Old May 22, 2012 | 11:49 AM
09CobaltSS1's Avatar
There's no predetermined numbers to just plop into the maf table(s) in order to scale the maf correctly. The best way of scaling it is to first disable your ve tables, set your editor to relearn ltft's, set up your editor so the car is running purely on the maf and flash that on the ecm. Then in your scanner make a custom pid of LTFT+STFT (pid6+pid7 I believe it is), add it into your scanner table, make a histo graph to match that of your maf tables, and then basically copy the trimmed numbers and paste special "multiply by %" the numbers into the maf table(s) in the editor after a nice long datlogging session. You will most likely have to do this multiple times. Then comes the fun of dialing in your ve tables..
See where I'm going here? You may want to either pay someone who knows their way around hpt to do this for you or pull up a comfy chair and do some serious reading on the hpt forums. There's a lot of good stuff to learn on there so just read up a bit before you get too crazy.
There even more to it than this than what typed, but this is basically the cliff notes version of what needs to be done. I hope this helps you a bit, or at least gets you in the right direction.
Old May 22, 2012 | 12:10 PM
it does help. Alot i have a tuner but i keep getting p1101 and i dont know why i heard that you have to recalibrate for the larger maf housing. i have replaced the maf three times the o2 sensors and everything possible. Im lost at this point i get fuel cut or spark blow out it seems as well with it only when p1101 comes on
Old May 22, 2012 | 12:12 PM
Map sensor has been replaced as well p1101 is MAF out of self test range
Old May 22, 2012 | 02:34 PM
Oh yeah, I forgot you mentioned that.. lol..
here are the steps from GM's service site that are points to check when this code is set
• A restricted or collapsed air intake duct
• A misaligned or damaged air intake duct
• A dirty or deteriorating air filter element
• Any objects blocking the air inlet probe of the mass air flow (MAF)/intake air temperature (IAT) sensor
• Any contamination or debris on the sensing elements in the probe of the MAF/IAT sensor
• Any water intrusion in the induction system
• Any vacuum leak downstream of the MAF/IAT sensor
• An intake manifold leak
• A supercharger inlet pressure (SCIP) sensor seal that is missing or damaged
• A manifold absolute pressure (MAP) sensor seal that is missing or damaged
• A stuck supercharger bypass valve--Refer to Boost Control System Diagnosis.
• A skewed or stuck engine coolant temperature (ECT) or IAT sensor--Refer to Temperature Versus Resistance.
• Any type of restriction in the exhaust system--Refer to Restricted Exhaust.
also check to make sure your barometer is reading correctly as well in hpt
Old May 22, 2012 | 03:29 PM
ok thanks. The car is highly modied and turbo'd I just dont know what else it could be. Its in a three foot staight.
Old May 22, 2012 | 04:58 PM
here is the way my turbo is set up sorry im not artist in a truck on my work computer think this could be the problem maf sensor is where the arrow is
Old May 23, 2012 | 05:55 PM
Old May 23, 2012 | 05:58 PM
05Slowline's Avatar
what size is your piping, should be 2.5 then 3" for bout 15 inches or so where the maf is, or just 3" cold side completely. that's how mine is atleast with no problems.
Old May 23, 2012 | 08:00 PM
same as yours but its prob a foot where the maf is
idk i getting weird **** maybe its leaking at the intake idk ill have to do a pressure check
Last edited by firefighter404; May 23, 2012 at 08:00 PM. Reason: Automerged Doublepost
Old May 23, 2012 | 08:06 PM
05Slowline's Avatar
yea, did you put rtv or anything around the maf? i had a nasty leak at mine at first, put some red rtv around it and is fine now
Old May 24, 2012 | 11:38 AM
i found an intake leak
Old May 24, 2012 | 11:43 AM
but ill do the rtv to the maf housing to
Old May 4, 2019 | 09:38 PM
James Northcutt's Avatar
Did you put the rtv around the maf housing or gasket? How did you do it? Im worried about getting it on the sensor. I have had nothing but problems since I changed my maf, the car is now undrivable and stuck at work. When I bought it it had an open airbox with no filter and maf was unplugged. I decided to get cia until I can replace stock airbox, I ordered maf and left it unplugged until the maf arrived. I then changed the maf at work and it hasnt ran right since. Tried unplugging it again it still wouldn't run right. It has since rained so I know if its wet it could cause this but it didn't look wet, I tried unplugging battery for 15 mins and haven't found any leaks in intake and like I said it ran fine until I changed maf, i was told maf had to be AC Delco for these cars so i ordered one it will be here tomorrow but now I'm wondering if it's not leaking at housing? Would it cause horrible air fuel issues?
Rodimus_Prime
Tuning
247
Jul 30, 2012 11:56 PM
ItalianJoe1
Tuning
Oct 12, 2008 11:55 AM
rrutter81
Tuning
Jul 29, 2008 10:17 PM
memphisr24
Tuning
Mar 17, 2008 07:36 PM
c24na
Tuning
May 22, 2007 11:42 PM
