War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
350Z vs Ion Redline
Old Apr 4, 2010 | 09:17 PM
ecotecturbo's Avatar
I never had a 350z beat me when i had an lsj running a 2.8 with gm stage 2
Old Apr 4, 2010 | 09:42 PM
OzzyruleZ's Avatar
Ever raced an HR Z? Or just 03-06? 07+ HR's are quite a bit faster.
Old Apr 4, 2010 | 11:49 PM
Maupin SS/SC's Avatar
agreed granted my buddy needs a tune he got beat by maybe an 07 z and hes got loooots of stuff lol
Old Apr 5, 2010 | 12:11 AM
leoaa777's Avatar
Originally Posted by ItalianJoe1
I got pulled by a "stock" LNF today.
Also got pulled by a trifecta tuned solstice. Amazingly, the solstice was just about as fast as the cobalt...
I handed you the keys after the race didn't I?? I told you can drive my Cobalt any way you wanted. Traction control on, off, cruise control on/off. However you want it. I have no reason to lie. I even pulled out my PAPER FILTER in front of everyone so you could see it.
You declined.
Old Apr 5, 2010 | 12:59 AM
OzzyruleZ's Avatar
hmmmmmmmmmmmmmm
Old Apr 5, 2010 | 01:07 AM
elecblue06's Avatar
You declined.
because clearly you had to be trifecta tuned.. with an hptuned car none of that means **** ..
Old Apr 5, 2010 | 01:12 AM
leoaa777's Avatar
The tune does not matter because there is none other than stock. I told him to drive my car however he wanted.
Your statement is even more ridiculous since you cannot turn "off" the HPtunes unless you have the software and rewrite the ecm...am I correct?
Old Apr 5, 2010 | 10:35 AM
ItalianJoe1's Avatar
You declined.
I really don't care bro. If your car is stock and runs like a tuned car, good for you.
Old Apr 5, 2010 | 02:48 PM
silver187666's Avatar
look what you started garry
Old Apr 5, 2010 | 02:58 PM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by maupin2.2
isnt a stage 2 tune going to run like crap witha 2.7? i very well could be wrong but i didnt think gm was that rich that it would even out. i have a stage 2 puley with custom tuning cai and gmpp catback and im going to run my buddys 03 track edition 350z that has tb spacer intake plenum highflow cat and borla catback, we will see how that goes
You are correct sir. I don't know why the guy is running a 2.7 pulley on a gm stage tune. if he is gm stage 2, the gm stage 3 pcm will make a dif. when i installed the gm stage 3 pcm on my car i felt a nice change in how the car performs.
to the op .... Z's are quick cars, and should be respected. nice run.
Old Apr 6, 2010 | 03:51 AM
  #36
OzzyruleZ's Avatar
Well I always thought Stage 2 and Stage 3 where the same in street mode with the exception of 100 octane mode and support for a dry shot. So if that is the case without 100 octane there will be no difference.
Old Apr 6, 2010 | 07:12 AM
  #37
Staged07SS's Avatar
Administrator
Administrator
nah .... GM Stage 3 runs a lot better in 93 octane mode than GM Stage 2. GM Stage 3 runs a 11.4 AFR versus GM Stage 2's 10.6-10.8 AFR (10.8 was my 07' GM Stage 2's AFR). A GM Stage 3 car in 93 octane mode (street mode) will pull about a car or so on a GM Stage 2 car.
Old Apr 6, 2010 | 10:52 AM
  #38
Black SS/SC 06's Avatar
I call next on the Z.............
Gary how is the "other" car coming along?
Old Apr 6, 2010 | 10:59 AM
  #39
OzzyruleZ's Avatar
Well meet me in Mexico and we can give it a shot!
The other car runs, we will be doing the IC and piping this weekend. And once I figure out how to get an airfilter onto it I will be driving it. And that my friend is one you don't want a piece of!!!
Learn something new everyday. Now I want to give him another run even more.
Old Apr 6, 2010 | 11:04 AM
  #40
I know, I just want a ride
Old Apr 6, 2010 | 11:05 AM
  #41
OzzyruleZ's Avatar
I don't know if I can do that. So much torque it'll twist the chassis.
Old Apr 6, 2010 | 11:07 AM
  #42
Lawlz
Old Apr 6, 2010 | 11:45 AM
  #43
OzzyruleZ's Avatar
Don't want to scare you. You have crime to fight!
Old Apr 6, 2010 | 11:54 AM
  #44
cakeeater's Avatar
On what pulley size? A 10.X:1 AFR is richer than an 11.X:1. As far as I know, the stage 2 comes with something like a 3.1 or 3.0" pulley and the stage 3 comes with something slightly smaller. If you saw mid-high 10.X's with the stage 2 and mid 11.X's with the stage 3 on a ~3.0" pulley (I'm assuming you are referring to your 76mm), it would seem the stage 2 tune would be the better bet for a 2.7" as you don't want to go much leaner than a high 11 on a canned tune... It's interesting that stage 3 runs leaner than stage 2.
Old Apr 6, 2010 | 03:38 PM
  #45
Staged07SS's Avatar
Administrator
Administrator
I ran a 10.8 AFR with the 77.9mm (3.067") Stage 2 pulley on the Stage 2 tune (07' revision of the GM Stage 2 tune), and I run a 11.4 AFR with the 76mm (2.99") Stage 3 pulley on the GM Stage 3 tune. GM Stage 3 is a different tune from the GM Stage 2 tune all together. it runs leaner, and has a little more timing (not much, but a little more). I will be trying out 100 octane mode this spring or summer and will be logging my AFR and timing.
It doesnt matter if the GM Stage 2 tune runs rich .... it's not smart to run a 2.7 pulley on the gm tune unless its customized and you have 60 lb/hr injectors.
Old Apr 6, 2010 | 06:02 PM
  #46
cakeeater's Avatar
I know. I was pointing out, to whoever said stage 3 will make a difference on the car in the OP, that if the stage 2 tune is richer than the stage 3 tune then the car in question probably runs better with it, although not well.
Old Apr 6, 2010 | 07:12 PM
  #47
Staged07SS's Avatar
Administrator
Administrator
Got ya
Another advantage of GM Stage 3 over GM Stage 2 is the adjustable rev limiter. I have mine set at 7250 rpm, and the extra 250 rpm over GM Stage 2's limiter helps keep the car in its powerband better during shifts.
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Silverbullet333
Sep 22, 2015 10:55 AM
