Old Sep 11, 2014 | 03:06 PM
  #12226
chefhhr's Avatar
Well I've got some money to blow...I guess I could look into doing a wider wheel and getting more "stanced". Maybe an 18x8.5...just not sure what offset I would run. There's not many HHR's that are stanced.
Old Sep 11, 2014 | 04:55 PM
  #12227
+35 is good, u can always use that wheel calculator to help give ya some numbers
do u have the brembos? i cant remember
u can probably even run +38 but the 35 is a safe zone from coil to fender
Old Sep 11, 2014 | 08:48 PM
  #12228
chefhhr's Avatar
I would like to still get a slight tuck without losing my ride height...I'm thinking an 18x8 +35 is where I'd need to be to pull that off and I'd probably have to still have the fenders rolled. Gotta do some research.
Old Sep 11, 2014 | 08:56 PM
  #12229
BPacak's Avatar
Vtec Rep
what does that even mean??
Old Sep 11, 2014 | 09:10 PM
  #12230
Bags
Old Sep 12, 2014 | 12:54 AM
  #12231
Old Sep 12, 2014 | 10:19 AM
  #12232
chefhhr's Avatar
Actually I'm not sure...lol
I want to go with a wider wheel without sacrificing my ride height. Does that sound better? Right now I'm slightly tucking my tires in the front.
Old Sep 12, 2014 | 10:35 AM
  #12233
Kyle09TC's Avatar
Run a 18x9.5 with a +30 to +35 offset and stretch some 215/40's like i did and you can still tuck tire, poke, and be "stanced"
Old Sep 12, 2014 | 12:18 PM
  #12234
paintballerr78's Avatar
Has anyone shimmed their rear wheels before?
Old Sep 12, 2014 | 12:54 PM
  #12235
Lol, only a few people
Old Sep 12, 2014 | 01:43 PM
  #12236
chefhhr's Avatar
Cool...thanks!
Old Sep 14, 2014 | 08:47 PM
  #12237
Kyle09TC's Avatar
Recently I've seen at least 4 cobalts other than Panda's and RandyO's on instagram that have shimmed the rear. Its starting to happen more. I'm going to wait it out a bit longer and see how it goes for them.
Old Sep 14, 2014 | 09:03 PM
  #12238
Was being sarcastic
Old Sep 14, 2014 | 10:32 PM
  #12239
Cobe's Avatar
Lovely potato picture. I have not even put 100 miles on it this year with all the work I have put into it! It is at GM getting the recall work done to it right now. Should have it back tomorrow. This picture does no justice. AT ALL. I have a photo shoot coming with mr.gudaguda
Old Sep 16, 2014 | 09:03 AM
  #12240
chefhhr's Avatar
Finally got with STR about custom drilling a wheel...they have some blanks right now and can do a set of the 601's in a 5x110. I'm ordering these today...18x8.5 +30 or +35 (he can do either one...need to make that decision before calling). Was going to do a 18x9.5 but I'm really concerned about clearance.
Old Sep 16, 2014 | 02:05 PM
  #12241
Kyle09TC's Avatar
if you're doing a 18x8.5 you should get a +30.. imo. that should be pretty close to flush i would imagine. I don't think you would have any issues on a HHR with a 18x9.5 +35 though
Old Sep 16, 2014 | 02:38 PM
  #12242
chefhhr's Avatar
Yeah I'll do the +30...there's someone else running this wheel with an HHR 18x9.5 and there's no way I'd be able to tuck the rears...with enough camber up front I may could get away with it. I'd rather play it safe with the 18x8.5 +30
Old Sep 17, 2014 | 10:10 AM
  #12243
sergiochaotik's Avatar
what I've noticed this past summer.
No matter what wheel you want, there's a way to make them fit.
Nobody thought my wheels would fit, but I'm actually tucking all 4 and I'm borderline sunk in the back, so much so, that I'm most likely going wider for my next wheels. Also, we fitted 13'' wheels with a negative offset on my buddy's 350Z.
Old Sep 17, 2014 | 10:20 AM
  #12244
what I've noticed this past summer. No matter what wheel you want, there's a way to make them fit. Nobody thought my wheels would fit, but I'm actually tucking all 4 and I'm borderline sunk in the back, so much so, that I'm most likely going wider for my next wheels. Also, we fitted 13'' wheels with a negative offset on my buddy's 350Z.
13 by what?
Old Sep 17, 2014 | 11:39 AM
  #12245
chefhhr's Avatar
I'm actually going to do 18x8.5 +30 up front and 18x9.5 +35 in the rear. I'm hoping to get them ordered this week...just waiting on details back from STR.
I'm running 225/40's right now...can I keep that tire all the way around with this new setup or do I need to look for new rear tires?
Old Sep 17, 2014 | 12:15 PM
  #12246
BPacak's Avatar
Vtec Rep
dont do that
Old Sep 17, 2014 | 12:17 PM
  #12247
chefhhr's Avatar
dont do that
I don't mind getting new rears...the 225/40 up front should be fine. What size do you recommend for the rear?
Old Sep 17, 2014 | 12:22 PM
  #12248
i dont know about that +35 on the 9.5. inner clearance comes to mind.
match the tires to the wheel if u run staggered. stretched 225/40 on the rears and like no stretch on the fronts. could look goofy
Old Sep 17, 2014 | 12:32 PM
  #12249
BPacak's Avatar
Vtec Rep
just do the 18x8.5 with 225/40 all around.
thats what i would do, but i mean its up to you.
Old Sep 17, 2014 | 01:09 PM
  #12250
chefhhr's Avatar
I want to do what makes the most sense...I think that would be easiest...+30 et all the way around?
