ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old Aug 21, 2015 | 03:19 PM
  #526
KMO43's Avatar
Originally Posted by hawkssoccer11
well then i guess youll literally be telling someone hold my beer while i play hockey haha
Wouldn't be the first time
I gotta get this stuff done tho and do my build thread
Old Aug 21, 2015 | 03:24 PM
  #527
hawkssoccer11's Avatar
nice haha
yeah i know you really need to get it done but thats what happens when you only have one car to use lol
Old Aug 21, 2015 | 03:37 PM
  #528
KMO43's Avatar
nice haha
I have another car to use but i have to finish it too. Its not my fault he didnt buy a kit and needed a custom dp and charge piping
Old Aug 21, 2015 | 04:29 PM
  #529
oh jeez hahahaha that sucks man
Old Aug 21, 2015 | 11:49 PM
  #530
taintedred07's Avatar
Will ported head, stage 2 cams, opels, 5th injector, full e85 be involved? That's what I'm wondering, if you could hit 550whp, 30-32psi.
Old Aug 21, 2015 | 11:54 PM
  #531
KMO43's Avatar
Ported head dual port actuator for testing and when i hit the rollers I'll be back on e25
Old Aug 22, 2015 | 12:11 AM
  #532
KMO43's Avatar
I think ported head at 28psi will be around 500 and on 30psi I'll be around 520. I think a full build stg2 cams and E will get you around 580hp
Old Aug 22, 2015 | 11:27 PM
  #533
Yea no one has documented, as far as I know, the results/gains from a ported lnf head - the exhaust side anyways, just rumors. I'm really interested to see your results and thank you for sharing!
Old Aug 22, 2015 | 11:50 PM
  #534
I'm also really interested in how the zfr bolt on with the .64 ar performs vs the 7163 .85 ar t25 with a manifold. I wonder if the .85 ar would slow spool a little for some more top end.
Old Aug 22, 2015 | 11:56 PM
  #535
KMO43's Avatar
The only way you'll find thst out is if u buy the non zfr
Old Aug 23, 2015 | 09:17 PM
  #536
I need one of these.
Old Aug 24, 2015 | 12:05 PM
  #537
KMO43's Avatar
Everybody does!
Old Aug 24, 2015 | 12:48 PM
  #538
Yes we do
Old Aug 24, 2015 | 12:54 PM
  #539
KMO43's Avatar
From how the turbo spools on my and Nathans car I don't think we'll have the same transmission issues which is a great thing and a good reason to buy one!
Old Aug 26, 2015 | 09:55 AM
  #540
KMO43's Avatar
I should finally be getting my actuator today (**** FedEx!) picking up an LE5 tb after work and the install is going to start Friday night! I am hoping to be done sat sometime and logging soon after. But I now have some boost leaks I have to fix so I've got lots on my plate but should be able to get it all done this weekend
Old Aug 26, 2015 | 10:00 AM
  #541
Dipped_Cobalt's Avatar
sounds good, good luck with it all.
Old Aug 26, 2015 | 10:02 AM
  #542
Let me know how that LE5 tb works out. Are you planning on just adjusting the base airflow tables for it?
Old Aug 26, 2015 | 10:06 AM
  #543
KMO43's Avatar
Thanks!
Ya I'll be doing trims first on low WGDC to get everything dialed then see what I get. On the bigger turbo I'm hoping it helps my off boost performance.
Old Aug 26, 2015 | 04:30 PM
  #544
KMO43's Avatar
Actuator is here!! Install is going down fri night!!
Old Aug 26, 2015 | 05:02 PM
  #545
get r done!
Old Aug 26, 2015 | 05:06 PM
  #546
KMO43's Avatar
get r done!
For sure! I'll be throwing the head together tomorrow night then ripping my car apart Friday.
@ Slowbalt2000 I'll have the build thread that you wanted next week!
Old Aug 26, 2015 | 05:16 PM
  #547
great, just no hurry, make sure all is done right the first time
Old Aug 26, 2015 | 05:41 PM
  #548
this never happens for me. Always try to take the cheap way out end up doing everything twice
Old Aug 26, 2015 | 06:38 PM
  #549
KMO43's Avatar
I have every part that I need I just have to have it done by Sunday night for work Monday AM. I've had my turbo off many times and thrown together 2 LSJs so I'm not too worried about the work I just need to keep a good pace and get it done with enough time to toon!
Old Aug 28, 2015 | 01:39 AM
  #550
KMO43's Avatar
Built the head tonight so I'm all ready for the install starting tomorrow!
