7163 zfr
Yea no one has documented, as far as I know, the results/gains from a ported lnf head - the exhaust side anyways, just rumors. I'm really interested to see your results and thank you for sharing!
I'm also really interested in how the zfr bolt on with the .64 ar performs vs the 7163 .85 ar t25 with a manifold. I wonder if the .85 ar would slow spool a little for some more top end.
I should finally be getting my actuator today (**** FedEx!) picking up an LE5 tb after work and the install is going to start Friday night! I am hoping to be done sat sometime and logging soon after. But I now have some boost leaks I have to fix so I've got lots on my plate but should be able to get it all done this weekend
Thanks!
Ya I'll be doing trims first on low WGDC to get everything dialed then see what I get. On the bigger turbo I'm hoping it helps my off boost performance.
I have every part that I need I just have to have it done by Sunday night for work Monday AM. I've had my turbo off many times and thrown together 2 LSJs so I'm not too worried about the work I just need to keep a good pace and get it done with enough time to toon!
