Ohh that's a nice idea, the E85 station is like 5 minutes away from my route when going home from my parents house so it's not bad for me but I only go on the weekends so I just need enough to to refill midweek and I'm good to go
See for me its 13hours away so we'd fill up 6 barrels and use 1 each and sell the rest. I'd run e47 as well with lobe injectors and with a pump I'd throw on a 50 shot
There hasn't been an update here for a while and I do not have any new info but I looked over my dyno tune last night and since I was on stock head, actuator and cams I had to run a very conservative boost ramp to keep the turbo surge down. I had low WGDC until 5000rpm. I already have a ported head and a 23 psi Turbosmart actuator plus this spring I will be doing Stg2 cams, injectors and coil packs. After all this is done I will be doing updates. I also have a customer with the ported head and stg2 cams so I'll have great info from 2 cars. I already hit a 3.9 sec 60 to 100 time but with the power coming on at 5k I'm losing a ton of time from the spool. I think a solid 3.5 sec run this year would make a nice goal!
I'm finally tuning Zack with his 7163, ported head and stg2 cam! We are doing 91 first then E47 but I will be updating here as we go!. His will be very similar to my car I believe I will make more power but will be very close!!
For sure I will be getting the first log here very soon but since it's just a base tune on 91 I'm not expecting too much. I'm doing a real mild 91 tune for him basically just to get him around on road trips when there is no E. The E tune will be more aggressive but have to finish the 91 first
So I did some digging and found a 56mm turbo dyno on 29.7psi so I have an idea of where about I should be on my 57mm turbo and I'd be quite happy with those numbers!!
