ZZ Performance ZZ Performance is a proud Supporting Vendor
ZZP 3in Downpipe problem!
Old Oct 13, 2010 | 07:08 PM
Phyrric's Avatar
Just talked to my dad, he said he saw the o2 bung pointing towards the drivers door when it was on the lift so i guess its not that either
Old Oct 13, 2010 | 07:09 PM
Whining-devil's Avatar
this is really weird
Phyrric's Avatar
Originally Posted by moranjames89
when I got mine I held it side by side with the stock one... idk man.
what problems are you having? vibrations? and it's not going to break hence the flexpipe.
Vibrations/humming, but it goes away when I'm in gear, it only happens when I'm in neutral I've only driven it from the side of my house into the driveway since it's been installed though
Old Oct 13, 2010 | 07:12 PM
ecot3c inside's Avatar
Originally Posted by Phyrric
Vibrations/humming, but it goes away when I'm in gear, it only happens when I'm in neutral I've only driving it from the side of my house into the driveway
I almost had the same problem with mine, just push the heat shields up or take them off. You can even bend the large 2 fins on the cat.
Old Oct 13, 2010 | 07:13 PM
i used to have the same dp as you have now and i remember mine touched the firewall a bit but i dont think it was anything like that
Old Oct 13, 2010 | 07:14 PM
the other dude is right, it would be pretty hard to put it upside down...
Old Oct 13, 2010 | 07:19 PM
Phyrric's Avatar
Is the heatshield the tin foil looking thing from the engine bay pics?
Old Oct 13, 2010 | 07:21 PM
yep! Just use your mechanical skills! to take off, or to not take off...
Old Oct 13, 2010 | 07:27 PM
Phyrric's Avatar
I'm just gonna bring it back to the shop on friday, tell them what everyone's said, and either have them fix it, or take it off and put the stock one back on for free, since they shouldn't have let it leave the shop, since they openly admitted it wasn't on right, and either find a different place or pay braulio to do it
Also, if I rip the heatshields off, and its actually the fin things causing the vibratation, how hard are they to bend?
Old Oct 13, 2010 | 07:39 PM
chris88z24's Avatar
Send it the **** back. You shouldn't have to hack up the bottom of your car in order to get a part to fit properly.
Old Oct 13, 2010 | 11:28 PM
  #36
Spanky's Monkey's Avatar
take it back to the shop.
Old Oct 13, 2010 | 11:42 PM
  #37
shadowfaxss's Avatar
this is probably the one I sent back last year. I've installed two of the downpipes for stock exhaust manifold. Neither one of them fit well. One was so bad we sent it back for a refund. That particular one was well against the side of the car at the top of the cat.
The shop that installed this did nothing wrong. Either return the downpipe for another and reinstall your stock pipe. ZZP will do nothing until they receive the downpipe and examine it.
Old Oct 13, 2010 | 11:43 PM
  #38
SunburstSS's Avatar
Dude slowwww down imma tell you what needs to be done i had the same problem almost with all my downpipes, now i installed my gmpp a while back and decided to swap downpipes later so i went ahead and did that but the downpipe kept hitting the firewall, so i readjusted my exhaust i had to push the exhaust forward starting from the closest pipe to downpipe, try pushing the exhaust forward from the back and u'll see it going away from the fireway, keep in in mind i have the gmpp exhaust on which is 3 peices, stock is one piece, but it's definatly worth a try, if need me to send you pics on mine, lemme know...
Old Oct 18, 2010 | 08:47 PM
  #39
damien's Avatar
Heh. I got the same problem.
I'm gonna try readjusting hangers. If that doesn't work I'll pay to get this piece of crap fixed
Old Oct 18, 2010 | 09:12 PM
  #40
CarsonTech's Avatar
I believe you guys when you say you had this problem. I had the same thing happen to me, not as severe, though. I bent the heat shield to the extreme so the cat wasn't rubbing itl as hard, it still rubbed the heatsheild a bit and vibrated a little. The tail of the extra o2 sensor in the bung for my wideband was RIGHT up against the firewall.
There is no way to change out the extra/front ow sensor on the ZZP downpipes without unbolting them from the header and dropping it a bit. This was ture for my Catted ZZP 3 inch DP and is still true for my catless ZZP 3 inch DP.
There is alot of extra room on the ZZP 3 inch without the cat, so nothing touches the firewall or heatshield besides the ass end of my wideband sensor.
The extra/front o2 thing is not too big of an issue with me, though. It forces me to get under the car and check things out when I want to recalibrate my wideband.
Old Oct 19, 2010 | 04:07 PM
  #41
recklessactn's Avatar
Poor design, you can see that the cat is in contact with the heat shield. Pushing your exhaust forward is only gonna put more stress on the flex and the exhaust will just move back to its resting position anyways once the car starts up. Send it back and get the CTI dp from ottp.
Old Oct 21, 2010 | 06:32 AM
  #42
CarsonTech's Avatar
You could do that... and/or make sure ZZP sees this so they know to fix the OPs problem and make sure future DPs are good to go. I am betting they have seen this thread or other complaints and are already working on this or at least investigating further.
Oct 21, 2015 11:57 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
