Accidentally floored it in 5th. Bad?
Old May 26, 2011 | 01:46 PM
  #101
damastah's Avatar
Originally Posted by sponge14
No, when you are in 5th gear (overdrive gear) and the engine is creating more torque then the clutch can handle, the clutch will slip, as in the 2 "halves" of the clutch start spinning at different speeds. When people use the clutch pedal it's the same thing, you have the 2 halves of the clutch moving at different speeds, and to get them to "mesh up" and get them to the same speeds, you slip the clutch with the pedal. The only time you really slip the clutch on purpose is when you are starting from a stop. On all other shifts the engine RPM will drop when you shift correctly and the clutch is really not doing much slipping at all.
ohh... i actually never knew this could happen... my clutch never slips when i do this.... i guess i should say never slips yet? lol
Old May 26, 2011 | 03:01 PM
  #102
sponge14's Avatar
It seems like some stock clutches hold up to tunes better then others. Mine was never beat on but it will slip even in 4th if I am not careful with running my tune.
Old May 26, 2011 | 10:08 PM
  #103
SSSnoop's Avatar
Seems there's a lot of 'suppose' going on here, and predictions of doom and gloom that are stretching way beyond OP's original question. He said he floored it for a few seconds, realized, then lifted.
And after the couple of seconds, all this hell is supposed to break loose. Okay, then.....
The answer in short is nothing terrible is going to happen even if your clutch slips for a few seconds - there's insufficient slip time to build up any significant heat or wear (unless the clutch is completely shot and you let it ride at redline for those few seconds! ).
As far as boost under load/no load, that is partly a function of exhaust pressure, but even a no-load rev would be enough to kick enough exhaust velocity into the turbo to generate some pressure (you won't get significant boost, but you should, in theory, get a couple psi). But the primary culprit is the bypass - its open in a no-load condition.
If anybody wants to prove to the board whether a turbo will build boost under a no load condition by pulling their bypass and corking it up with a load of duct tape, that should definitively answer the question!
Old May 27, 2011 | 11:33 AM
  #104
094doorSS/TC's Avatar
ya i agree with you on the boost thing, i was not buying the no load at idle so no boost line.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
