Bnr k04-gt28
Old Feb 4, 2011 | 10:36 PM
  #951
SKY888's Avatar
Originally Posted by HHRSSouth
I will point this out though, the 2860 rated at 35 lbs/min) flows more air then the stock K04(32 lbs/min). With good tunes people are making 340 whp on the Delta platform, a few have even managed 350-360 whp with a stock K04 with bolt ons.
So in theory the 2860 should make more whp then the stock K04 and keep making power higher up in the rpm band where the K04 drops off.
We aren't talking huge whp gains, but there should be some there none the less and you should be able to maintain it higher in the rpm band.
I know this is the cobalt site and talking about BNR turbos.
but when you mentioned about a kappa making 370whp using 2871 BNR turbo, I then provided the dyno graph tuned by DDM.
and I provided statements by DDM talking about 2860 (320whp) and 2871 (370whp) on a kappa platform.
yeah, 2860 making 320whp on a kappa platform is very realistic.
Which I was talking about
Yeah, 2860 on a cobalt platform, will probably be around 340-360whp depending on the tune/dyno....and probably 2871 on a cobalt platform will probably be around 370-400whp, depending on the tune/dyno
Old Feb 4, 2011 | 11:40 PM
  #952
Turbo'dSS's Avatar
Originally Posted by tglems
I will try to post it up in the AZ B.S. thread! Hopefully somebody will come with me
Well i keep an eye out in theat thread then!
Old Feb 5, 2011 | 12:48 PM
  #953
iboost's Avatar
sub'd
Old Feb 5, 2011 | 01:00 PM
  #954
bphage's Avatar
So does anyone know how this might compare to the "LNF Big Wheel Turbo" for the GXP and if it would work on the Cobalts? Looks like we may have some great options for turbo upgrades, can't wait for the dyno on the stage 1 and 2.
The Home of WERKSracing products!
Old Feb 5, 2011 | 01:59 PM
  #955
sundevil07's Avatar
ill be there for sure tyler
Old Feb 5, 2011 | 04:08 PM
  #956
hunter19707's Avatar
What are the chances of blowing my pistons with this upgrade? I've noticed some of you guys have replaced them.
Old Feb 5, 2011 | 05:05 PM
  #957
Turbo'dSS's Avatar
depending on when, id like to come.
Old Feb 5, 2011 | 05:16 PM
  #958
SKY888's Avatar
lnf big wheel turbo, is just an upgraded bigger compressor wheel.
BNR turbo upgrade is a total replacement of both turbo and compressor wheels with either gt2860 or gt2871 garrett turbos.
Old Feb 5, 2011 | 05:31 PM
  #959
cubaniche's Avatar
On the contrary. This turbo will get us the power we want while still being efficient and not out of its efficiency range like pushing the K04 to the max. That combined with a good tune and you should be fine. Dont severely mess up an NLS while on the tune pushing that much power and you should be fine....if you even NLS at all.
The ones that have replaced them was either out of necessity or because they were building their engine or just for plain old peace of mind, like me lol
Its certainly safer to push the engine further with forged internals
Old Feb 5, 2011 | 05:45 PM
  #960
Turbo'dSS's Avatar
Not needing to replace internals, another plus side to this swap. Although id like to get the zzp valve springs.
Old Feb 5, 2011 | 06:13 PM
  #961
So, if it ever happens, I'll look you up if I ever need help replacing some pistons!
Also, I haven't NLS since I received my TF tune.
Old Feb 5, 2011 | 08:54 PM
  #962
iboost's Avatar
The stage 2 bnr it says you need a custom hotside charge pipe and spacer. Anyone no anything about this? Can you mod a charge pipe you have? What about this spacer?
Old Feb 5, 2011 | 09:34 PM
  #963
Turbo'dSS's Avatar
Im pretty sure they fixed the need for a new charge pipe. They're welding an extended tip on em now. Not sure for the spacer tho?
Old Feb 5, 2011 | 10:13 PM
  #964
BlackBeast!'s Avatar
you need a custom chargepipe for the bov
Old Feb 5, 2011 | 10:18 PM
  #965
iboost's Avatar
Well I have my Dejon chargepipes with a HKS BOV already. So I should be good with that?
Old Feb 5, 2011 | 10:21 PM
  #966
Turbo'dSS's Avatar
yeah that should work. It sucks for me cuz ill have to get a flange welded onto my Hahn piping. but thats not a big prob.
Old Feb 5, 2011 | 10:23 PM
  #967
iboost's Avatar
Ok cool. I did email them, but its the weekend so I prolly won't hear anything from them until monday. Now I just need to know about this spacer. Cause I'm like a paycheck away from doing thiss....
Old Feb 5, 2011 | 10:25 PM
  #968
Turbo'dSS's Avatar
yeah i want to do it sooo bad but id like a bigger intercooler, new clutch, new tires, 2nd interceptor, and get my rims powdercoated first. And im trying to figure out what im going to do about the core charge. lol!
Old Feb 5, 2011 | 10:29 PM
  #969
iboost's Avatar
yea I hear ya man
Old Feb 5, 2011 | 11:12 PM
  #970
cubaniche's Avatar
Well then you should be good!
I have two friends that are mechanics and were dying to tear into the LNF so they did the work.....I just helped lol
Old Feb 5, 2011 | 11:18 PM
  #971
cubaniche's Avatar
Dont forget that you will want the retainers as well. Thats why ZZPs kti cost less, cause the retainers arent included. The retainers are an extra 90 bucks from them. Still cheaper than supertech.
Its a good move to upgrade them nonetheless.
Old Feb 5, 2011 | 11:21 PM
  #972
Turbo'dSS's Avatar
thanks for that info!! ill add em to the list. along with their cams its looking like. lol!
Old Feb 6, 2011 | 03:05 PM
  #973
Matt M's Avatar
I'm running stock retainers with my ZZP valvesprings. You don't actually need to change the retainers to run ZZP springs unless you are running quite a bit more lift than the stok cams provide.
Old Feb 6, 2011 | 03:44 PM
  #974
cubaniche's Avatar
Thats great! Speaks well for your spring kit
Its just a suggestion to people. Alot of members have voiced their interest in your new cams anyways. If your going to open her up to work on the springs you may as well replace the retainers too. Some of us rather not go back in to replace something that may fail later on
Old Feb 6, 2011 | 03:59 PM
  #975
Turbo'dSS's Avatar
That's the way I feel. If im swappin springs might as well swap retainers too. Lol
