code p0101
Old Jan 4, 2015 | 04:04 PM
mikeluis92's Avatar
code p0101
Having this come up on wot anyone had this happen??
Old Jan 4, 2015 | 04:13 PM
09CobaltSS1's Avatar
List your mods.
99% of the time it's a boost leak. There are only roughly 84125414526541265421 threads touching on this!
Old Jan 4, 2015 | 04:15 PM
Bika's Avatar
Fail Less.
Maf frequency out of predetermined range.
dirty maf, aftermarket intake skewing readings, bad maf, or something similar.
Old Jan 4, 2015 | 04:16 PM
Originally Posted by 09CobaltSS1
List your mods.
This.
Search before you make a thread, even just google cobalt ss po101 pulls up a ton of results
99% of the time with the LNF the Po101 is a boost leak
Old Jan 4, 2015 | 11:11 PM
mikeluis92's Avatar
Thought maybe someone has had this happen and knew a way to fix it I searched it bt didn't find much , I did recently do boost leak test and fixed the 2 on intercooler piping we boost leak tested again and nothing else came up, I did purchase new maf sensor still coming up,
So far got hahn ic, intake , and chargepipe, hp tune , bws , upgraded fuel lobe intake cam 26 psi , could I need a retune??
Old Jan 5, 2015 | 09:50 AM
mikeluis92's Avatar
Up
Old Jan 5, 2015 | 09:51 AM
mikeluis92's Avatar
Searched for boost leak today full boost leak test nothing came up, anyone she'd some light??
Old Jan 5, 2015 | 09:52 AM
mikeluis92's Avatar
So possibly my hahn intake is leaking from somewhere ?? It is fine tho no cracks or nothing ..... it's maf code ..
Old Jan 5, 2015 | 10:11 AM
Yes, we're all very aware the P0101 is a maf code.. lol
Is there a vta bov in the system, or is it just the stock bpv?
Old Jan 5, 2015 | 10:12 AM
umrdyldo's Avatar
Try putting stock intake back on. I dont think we have seen hardly any MAF failures.
As said it's usually a boost leak or an intake problem. Most people think the Hahn intake is one of the worst.
Are you tuned for it? What are your fuel trims with it?
Old Jan 5, 2015 | 12:01 PM
mikeluis92's Avatar
Dam o don't have stock intake as I purchased this car used bt it only had hahn ic, hahn chargepipe , and hahn intake...
Old Jan 5, 2015 | 12:06 PM
mikeluis92's Avatar
I am tuned for it, fuel trims? I don't tune the car so I don't know bt my tuner did say I was getting good fuel cus on the highway we did have the boost turnt up to 29 psi until I started getting spark blow out , so we turned boost down to 24 26 psi ,had advance auto part plugs ,got the 1 step colder plugs threw them in Havnt retune yet bt when my tuner told me to punch the car after putting plugs in that's when it threw the p0101 and no cel just throws code car goes into limp mode .. no boost and it does it every now and then ... and when I put in the new plugs gapped them at .32 as per tuner 1 step colder and am still getting spark blow out..
Old Jan 5, 2015 | 12:07 PM
mikeluis92's Avatar
I'm guessing I need a tune?? Bt what gets me is the p0101 code for maf... cars building boost and hitting hard and other times just dies out goes into limp mode..
Old Jan 5, 2015 | 12:10 PM
umrdyldo's Avatar
Wait? Your tuner thought 29 psi was ok?
You don't have to be a tuner to read your fuel trims. I use a bluetooth adapter with Torque android app.
You should be on stock plugs gapped close to stock or at 0.35
I'm still guessing you have a boost leak or your intake/tune is screwed up.
Old Jan 5, 2015 | 12:12 PM
mikeluis92's Avatar
Stock bpv on a bws built by Mikes Turbo just changed compressor wheel, I did full boost leak test would that have told me if I was leaking from there??
Nah we put boost back to 24 psi cus he saw it wasn't running right
Old Jan 5, 2015 | 12:13 PM
mikeluis92's Avatar
I have rpd bt it says fuel pressure that it?? Usually at idle like around 468- 600 and I've seen it go up to 2500 psi... bt those numbers are not exact just from what I can remember,
Old Jan 5, 2015 | 12:44 PM
umrdyldo's Avatar
Your boost leak test is done from the upper charge pipe, it would not tell you if you have leaks in the intake or issues with the turbo.
Old Jan 5, 2015 | 12:48 PM
LNFTX's Avatar
https://www.cobaltss.net/forums/how-...ss-lnf-223319/
Old Jan 5, 2015 | 02:46 PM
mikeluis92's Avatar
I did full boost leak test already on the car wasn't searching for thread thank you tho
Old Jan 5, 2015 | 03:16 PM
I would bet you still have a leak. This guy had a similar issue and claimed he didnt have a boost leak, yet it ended up being a boost leak https://www.cobaltss.net/forums/comp...-sedan-314303/
Old Jan 5, 2015 | 04:15 PM
Who's your tuner if you don't mind me asking?
Also, just for the heck of it, have you pressure tested just the Hahn ic you have? They used to be pretty notorious for blowing out the welds on the end tanks.
Old Jan 5, 2015 | 04:24 PM
mikeluis92's Avatar
Edgar with hptuners down here in south fl and boost leak tested intercooler was no leak
We did pressurized the system
Old Jan 5, 2015 | 04:28 PM
umrdyldo's Avatar
what pressure did you go to?
Old Jan 5, 2015 | 04:37 PM
mikeluis92's Avatar
I am not positive since I took it to a shop ..
Bt they told me the ic could've cracked or been faulty so they did test that.
Old Jan 5, 2015 | 04:45 PM
mikeluis92's Avatar
I saw his thread of his problem bt his boost and it was throwing cel 30 secs after running the car I can run my car for a while before that codes comes up takes couple hours for it to show... and it makes boost to 24 psi ... I don't see any direct issue that is the direct cause. Everyone says it could be this or it could .. so gust rating I'll check the car . And getting retune in a bit and tuner going to data log the car..
