emission codes, evap purge
Old Jul 11, 2011 | 05:40 PM
dino75's Avatar
I have a 451 and 496 codes on my ss tc. i was told by many to retune my car and richenen it up but my check engine light is still there. should i change my evap purge selonoid? if so can i get that part at a local store or do i gota go thru gm, thanks guys appreciate it
Old Jul 11, 2011 | 07:34 PM
RYRO14's Avatar
Yeah replace the EVAP purge solenoid and if that doesnt fix it then replace the vent valve in the rear of the car and that should fix it, has nothing to do with the tune.
Old Jul 11, 2011 | 09:24 PM
Mike_peperni's Avatar
Just get the part and install it yourself, very easy to do, its on the top of the intake manifold, just unplug the sensor, remove the nut and swap the sensor. You can unplug your battery during the install to clear the code or if you have a scanner and can remove it then its alright...
Old Jul 11, 2011 | 09:25 PM
lockdownlegend's Avatar
just did this....googled the part number and had it shipped to my door for 26 bucks. it was from rms motorsports i think. anyway my car would start rough and need me to give it gas after a fillup. threw the same code and now its fixed
Old Jul 12, 2011 | 08:27 AM
Gremlin85's Avatar
Mine threw the same P0496 code for the evap purge solenoid. I just ordered a couple new ones off a member here and they should arrive by the end of the week. Just in time for me to get inspected
It seems that these fail quite often.
Old Jul 12, 2011 | 08:38 AM
umrdyldo's Avatar
Had 455 and 496. Mine was Evap Purge selenoid
Old Jul 12, 2011 | 11:32 AM
JacBlackSS/TC's Avatar
I just replaced mine waiting to run of gas to see if it fixed it
Old Jul 12, 2011 | 08:50 PM
dino75's Avatar
I just bought it today. thanks guys for the advice. when i install it, should i clear the code? i gota get inspected asap
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
