holding boost issues...
When i go into full boost with my car it makes a loud pop and loses all boost until i let off the petal and press it down again and continues to keep doing that. I have replaced the lower map sensor and new plugs. Never started doing it until i put the inter-cooler on and i cant seem to figure out what is causing it and i would def like it fixed cause its depressing to not be able to get into my car and not be able to hold boost. Any ideas what would be causing this
yeah i will reach full boost through the tune and gms1 but it seems like right when it hits higher boost levels it just cuts out and loses boost. once i take my foot off and press it back down its back then cuts out. i have no idea what the problem is and its frustrating so im throwing it on here to see if anyone has had this problem
okay ill def check those out thanks
Sl0wbaltSS
Nov 21, 2018 11:11 PM
