holding boost issues...
Old Jul 7, 2011 | 05:51 PM
Souperman's Avatar
Unhappy holding boost issues...
When i go into full boost with my car it makes a loud pop and loses all boost until i let off the petal and press it down again and continues to keep doing that. I have replaced the lower map sensor and new plugs. Never started doing it until i put the inter-cooler on and i cant seem to figure out what is causing it and i would def like it fixed cause its depressing to not be able to get into my car and not be able to hold boost. Any ideas what would be causing this
Old Jul 7, 2011 | 06:02 PM
05Slowline's Avatar
sounds like a chargepipe blowing off but doesn't make sense that it would work again right after, maybe not blowing off completely that would be very odd though...
Old Jul 7, 2011 | 06:10 PM
ronn's Avatar
Sounds like one of the pipes/hoses connected to the new IC is letting go. I take it you swapped out new hoses/fittings on the IC? Those have to be on super tight and fit properly.
Old Jul 7, 2011 | 06:12 PM
Souperman's Avatar
yeah i will reach full boost through the tune and gms1 but it seems like right when it hits higher boost levels it just cuts out and loses boost. once i take my foot off and press it back down its back then cuts out. i have no idea what the problem is and its frustrating so im throwing it on here to see if anyone has had this problem
okay ill def check those out thanks
Old Jul 7, 2011 | 06:24 PM
Souperman's Avatar
Would the stock coldside piping be a issue or problems with my mods since its pretty much only I haven't upgraded
Old Jul 7, 2011 | 07:34 PM
Souperman's Avatar
Wrenched down on all the tbolt clamps and well its running like old again thank you for the advice
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
