Another EFR takes a S*!t
Well I wanted to mount the Turbo today but I ran out of time and energy.. I fabricated a plate, tapped it and put 1/4 fitting in it for the oil return line. Found a thermostat housing for the extended tip and drilled the holes out to make it fit. Also made a plate to block off the breather line.
Tomorrow I'm gonna mount the Turbo and Dp, make an intake, install charge pipes/IC, and front bumper. Also an oil change..
I haven't decided if I'm gonna run the stock tune or custom tune yet.
Donkey the breather line fitting has make type part with an oring that goes in that hole. Im not sure if a block off plate will keep oil from leaking out. Hope it works for you tho. I just thought you may want to know
