Bad week
Old Feb 28, 2011 | 01:20 PM
paintballerr78's Avatar
Bad week
well i as having misfire issues with my car that are now fixed due to a bad coilpack. Now i went to install the coilpack and went to take the old one off and the clip that goes into the coilpack the top broke off. Do i need to buy a all new harness or can i just get the clip
Old Feb 28, 2011 | 02:47 PM
Iam Broke's Avatar
You were supposed to remove the light gray retainer by depressing the little center clip and pull it back & off towards the firewall, then depress the black tab it is keeping latched and pull the connector off the coilpack also toward the firewall. Looks like you were trying to pry it off the coilpack?
Remove the connector and if the weather seal is still intact forget about it. Splicing on a new plug is ftl.
Solder and heat shrink would be acceptable but if the old one still seals, fuggedaboudit!
Old Feb 28, 2011 | 03:12 PM
Iam Broke's Avatar
See if you can find a part number on the connector when you get it apart & look here...
| pi | wiring-connectors | gm | pigtails | 4-cavity | ACDelco TechConnect
Old Feb 28, 2011 | 03:45 PM
gone_in_10_sec's Avatar
OP - do you have heat wrap on your charge pipe?
Old Feb 28, 2011 | 04:30 PM
DillySS's Avatar
I did the same thing when I put on my intake, really don't know what to do with it but it still makes connection and doesn't disconnect without losts of force.
Old Feb 28, 2011 | 04:50 PM
InfraRedline's Avatar
Hey Cody I didnt break it off when I swapped them yesterday, shoulda let me do it again
And yeah as they said if you can just get it sealed and it makes connection youll be golden
Old Feb 28, 2011 | 08:47 PM
redsport's Avatar
I think your car hates u cody
Old Feb 28, 2011 | 10:04 PM
Malaclypse's Avatar
The weather pack is fine... put a zip tie on that bitch.
Old Feb 28, 2011 | 10:55 PM
I think you granny shift and cant drive for sack....Wait till i come home game over bitch *****
Old Mar 1, 2011 | 07:19 AM
redsport's Avatar
I got something for u
Old Mar 1, 2011 | 05:49 PM
Its in his middle pocket ^
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 13, 2015 09:32 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
