Best bang for the Buck
Old Mar 9, 2011 | 02:52 PM
  #51
SSlobalt's Avatar
Originally Posted by BYT*SS*TURBO
yup
Ugh. How do you lower it? With straps or a seesaw-method, or something like that? Also, do you separate the rack from the subframe or just disconnect it from the steering rod somehow?
Old Mar 9, 2011 | 02:55 PM
  #52
BYT*SS*TURBO's Avatar
Just disconnect the steering rod, its easy to do.
We lower it with 2 jacks, its not the heavy either with 2 people working on it.
Old Mar 9, 2011 | 02:56 PM
  #53
Supercharged Guy's Avatar
Get the Spec stage 3+ and call it a day
Old Mar 9, 2011 | 03:18 PM
  #54
silverbullet08's Avatar
I did my clutch in my lsj and left the subframe in. I losened the subframe bolts and it gave me a little more play when separating the tranny, It would probably make it easier to drop the whole thing though. It took a little sqirming and elbo grease to get the new clutch bolted up. whole process took me about 3 hours then just added my fluids. I havnt heard abou this KY clutch... thats a good price im going to look into it for my LNF now.
Old Mar 9, 2011 | 03:32 PM
  #55
Iam Broke's Avatar
Forget the ZZP rod, you won't need it with a SPEC when properly bled. I took mine out.
Old Mar 9, 2011 | 06:00 PM
  #56
ronn's Avatar
Originally Posted by CudaJoe
thats good to know
I find the wierd thing is that I dont smell burning clutch and I dont smell burning tires???
I dont hear anything other than the rpms climbing to indicate what is slipping?
YEAH, definately had traction on the whole time... I never saw it flashing. Good deal. New clutch it is then.. so now back to the search! something that can handle 400trq
I have same HP/Torque as you..no problems with stock clutch slipping. If you floor it at 3000 RPM in 3rd and the rpms climb rapidly without corresponding increase in speed, you're slipping. Wheel traction shouldn't be an issue in 3rd on a dry surface. Do a ricer run from 60-90mph in 3rd (around 4000-6000 rpm). If you're not getting 4.5-4.8 sec you *could* be slipping, since we know the dyno #s should support that result (mine does).
Old Mar 9, 2011 | 07:06 PM
  #57
Joemann892's Avatar
Here's the dyno from the tune.
Clutch slippage? or tires spinning on the roller?
does that look just a bit similar? I think so and its clutch slip. I ordered KY clutch the other day and it comes with new slave TOB for 387 shipped... almost can't go wrong with that and they claim 420 hp ... dont know why he didnt give me torque rating.
Old Mar 9, 2011 | 09:16 PM
  #58
slowstang's Avatar
Joe, I researched about the Spec lightweight option and i'm pretty sure it's 14 or so holes drilled in the clutch just like a cross drilled brake rotor.
I'm in the same boat with near the same mileage. Mine will hold from a roll but on a sticky dragstrip it was slipping pretty bad. I plan on installing a new stock clutch with new fluid just because this one has treated me well with making 366wtq. I'm at the point where I won't be racing it at the track that much anymore also.
Old Mar 10, 2011 | 04:54 PM
  #59
Matt M's Avatar
Originally Posted by Chevycobaltss3
i just say go with ky clutch lol
Have they corrected their offset issue? We keep getting customers emailing asking if our adjustable clutch rod will fix a clutch that disengages too high. They all have KY clutches.
Old Mar 10, 2011 | 06:16 PM
  #60
turbohornet88's Avatar
matt. would someone need your adjustable clutch rod if they get your stage 4 clutch.
Old Mar 10, 2011 | 07:15 PM
  #61
sponge14's Avatar
Matt, since you have jumped into this thread.... What clutch do you recommend that can handle about 450ft lbs that you have seen to give the least problems and best lifetime?
Old Mar 10, 2011 | 07:30 PM
  #62
good question. this is what im looking for too.
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
dennis69
Oct 20, 2015 04:49 PM
riceburner
Sep 27, 2015 11:10 PM
Cptnslo
Sep 24, 2015 09:32 AM
