Cobalt SS: Project 25G
Old Sep 25, 2013 | 12:47 PM
  #351
N1ckateen's Avatar
Payam on my setup I'm running the factory bc. And when James had my setup he was running an ebc and he didn't get any surge either. I think term is correct on his theory about the wg.
Old Sep 25, 2013 | 01:02 PM
  #352
Fastgti69's Avatar
Originally Posted by Terminator2
GMtech is too arrogent IMHO. I do not like dealing with him because he will never admit he is wrong even if he is. John (09cobaltss1) gets my recommendation if you were not picking me. It should boost 22 psi or so with the 1.5 bar spring but if the rod is too short it will surge badly as it spools which could hamper its ability to build boost safely and properly which explains the 17 psi max you are seeing (assuming all leaks are fixed).
I agree with GMtech, that's why I said he wouldn't tune me or anyone else for that matter LOL. But yea, I guess I'll try it out. I have no other options besides goign back to the WG.
The turbo isn't spooling "too fast" for an MBC. There are plenty of turbo's that spool much faster with no issue. Could the EBC help bandaid the issue? Perhaps. As term said, loosen the wastegate rod and try it out again with the MBC still hooked up to eliminate any more variables. IWG's have never been my favorite, but you gotta do what you gotta do.
I'm not saying spooling fast for MBC, I'm saying spooling too fast for the car to keep up. This turbo flows a nice amount of air pretty quickly too. My turbine is same as a 20g so it actually spools really fast once started LOL. I'll try the WG thing.
Going to go back to the damn WG. Trial and error. At least I've learned so much about my car and how to work on it's getting easier. Esp since my buddy got a lift at his shop, I can go there anytime I want. I was there till 4 am 2 nights ago when I fixed my lower charge pipe sensors etc.
Old Sep 25, 2013 | 02:08 PM
  #353
ATLsilverSS's Avatar
You have a larger turbine than the 20g. My turbine is a 20g turbine. I get the same surging and im on a zzp mani, tial 38mm wg with 8.7psi spring, hallman pro mbc set to 23psi. I have not begun tuning yet tho so please nobody say its the tuner. I just want to know if i need to fix sonething before i begin tuning.
1st and 2nd gear no surge, 3rd a little, 4th and 5th are horrible
Any ideas???? In thinking i just need to up the wg spring
Old Sep 25, 2013 | 02:43 PM
  #354
Fastgti69's Avatar
Weird ****... Up that spring to a 1 bar. That should be enough. I'm guessing these 25g are bad combo with 20g wheel or anything td05. Idk though.
Old Sep 25, 2013 | 03:00 PM
  #355
You have a td06sl2 turbine iirc. James was a t67. Mine is the small wheel wirh a td05
On a side note i need to do a boost leak check myself. I suspect im either leaking at those stupid 90* elbows at the tr12 ot my intake mani gasket. Ive got an extra intake mani gasket but i still have to take it off one last time so i was waiting to swap that out.
Old Sep 25, 2013 | 03:01 PM
  #356
N1ckateen's Avatar
I have the one James had now with the t67. I don't have any issues other than low horsepower.
Old Sep 25, 2013 | 08:28 PM
  #357
Fastgti69's Avatar
I would like to see your logs... too bad i cant lok
Old Sep 26, 2013 | 08:52 AM
  #358
raver0789's Avatar
On your MBC do you have a spring pressure setting? On my truboost it has a spring rate which you are supposed to set to 1psi your factory spring pressure rate. So 9 psi on the zzp kit so I set it to 8. The higher the spring pressure I set it to the faster I can get the snail to spool up. However...if it is set too high it will cause surging and spiking of boost. Just throwing that out there.
Old Sep 26, 2013 | 12:30 PM
  #359
Fastgti69's Avatar
Nah, no spring pressure thingy. It's regular hallman pro boost controller. IDK really what else I can do with it except turn it lol.
Old Sep 26, 2013 | 07:33 PM
  #360
Fastgti69's Avatar
Here's a little pull today. Was about 80 degrees out second gear only... You can't hear the flutter too much cause of shitty youtube. If you put on some headphones maybe. It's much quicker flutter sound than before. W/e though 7.5k rpm redline too so
Old Sep 26, 2013 | 09:19 PM
  #361
N1ckateen's Avatar
perfect for you to post that. I just took a video about 15 minutes ago on my way home. 2nd and 3rd. put new plugs in with a smaller gap last night. helped my 2nd gear breaking up issue and also replaced valve cover gasket and purge solenoid.
Old Sep 26, 2013 | 09:44 PM
  #362
Payam you need a new camera guy lol
Old Sep 26, 2013 | 09:54 PM
  #363
Fastgti69's Avatar
Cobalt ss 25g - YouTube
Looks pretty good man. I'll try n get a vid with second and third gear. Tomorrow I'm going to try and loosen the wastegate preload.
LOL, I was recording with my cell phone. It's pretty hard haha. Hopefully tomorrow it will change with less preload. I just don't want it to be worse and less power!
Old Sep 26, 2013 | 09:56 PM
  #364
N1ckateen's Avatar
I used my Iphone 5 to take my video. try taking a video at night. then you don't have the sun glair
Old Sep 26, 2013 | 10:06 PM
  #365
Wert842's Avatar
Hell. Should do what I do. Use a GoPro at wide angle and use a 3m mount on the dash bezel. Works so good. Sounds messed up cause I put the stupid waterproof back cover on cause I can't find my other cover. Boo.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Sep 26, 2013 | 10:24 PM
  #366
N1ckateen's Avatar
looks like a really good solid quick pull. wish I could rev to 7 grand
Old Sep 26, 2013 | 10:28 PM
  #367
Wert842's Avatar
I only revved to 6800 on that pull. I'm still on stock springs and only rev to 7200 when racing at the track really.
Old Sep 26, 2013 | 10:34 PM
  #368
N1ckateen's Avatar
my rev limit is set to 6800 according to james. although it almost seems like i'm hitting rev limiter at stock rev limit.
Old Sep 26, 2013 | 10:36 PM
  #369
Wert842's Avatar
Is that according to your dash or HP tuners?
  #370
09CobaltSS1's Avatar
That sure as hell looks like a solid 7k to me homeboy..
Old Sep 26, 2013 | 10:40 PM
  #371
Wert842's Avatar
Lol. Its the camera angle.
Old Sep 26, 2013 | 10:44 PM
  #372
It's my butt angle....
  #373
N1ckateen's Avatar
in my video there when I stop in 3rd. that wasn't me letting off the pedal. that was me hitting rev limiter. at like 6200....
Old Sep 27, 2013 | 12:19 AM
  #374
Fastgti69's Avatar
We'll see what happens. I got a new file for using my regular boost controller solenoid. Tomorrow morning I'm going to do my wg rod as well. And.... I'm going to check out a 335 I found.
Old Sep 27, 2013 | 10:25 AM
  #375
Kbbalt's Avatar
Wert that was a smooth Quick Pull, Who does your tuning?
