Custom Cold Air Intake
wow... wait good **** that you made your own intake, BUT isnt that pipping like plastic?
also cant you get that at pepboys?
also doesnt the MAF sensor HAS to be at the exact position as the stock?
if it works fine good but i would recommend you to get a better one....
It is plastic, and it feels like it will easily crack... BUT, it does work. as for their filters, dont buy them. I made a spectre intake for my gfs car and my sisters car. The piping works but if you tighten it too much you will crack the plastic. the filters were a mistake. I bought the gf a K&N filter last year.
The MAF housing looks smaller than stock which is going to cause the car to run rich. The ECM will try to correct it but often times it will over or under correct with the LTFT and STFT so the car is probably going to run funny (it will sometimes bog, misfire and generally feel lazy)
Last edited by Terminator2; Jan 6, 2010 at 03:01 PM. Reason: Automerged Doublepost
snip...
And to the pic poster...is this Spectre MAF tube piece plastic? It looks metal like the flange is welded on there. Just curious.
I know you weren't asking me, but I've been running a CAI version of this for a while now. The MAF adapter is actually aluminum, but the rest of the piping is plastic.. It has actually worked great for me so far. $75 in parts + an hour of your time + a tune = a relatively decent CAI setup
Maybe the stock tube from the turbo up is 3.25" , I don't remember. Have to crawl up in the attic I guess and see unless someone knows. Might be a cheap winter SRI option for me. I know Term posted all the sizes before, I'm just ADD.
Dude, I tried working on that **** today and had no luck with the car wanting to run. I gotten the bigger air filter from Spectre, which fit in the aluminum MAF adapter perfectly. The car would not start. It will go on for 3 seconds and off it suppters itself because the MAF was being an ass. So, I call it a failure. I did exaclty the same way that pic looks, put the adapter sealed the air filter tight with the MAF Adapter to the intake so no leakage would take place. That's when I gave up and turned everything in. I tried to use the KN at first, but it wouldn't stay on the MAF because of the clamp. So I have no idea how he got his working. Lost the first screw to the factory MAF sensor, which I have the other one on, plus the bolt on the bottom of the stock airbox. Does anybody know where I can get the screw for the MAF sensor and the bolt for the bottom at?
Thanks for the feedback. If the adapter is aluminum and 3", slap a 3" K&N cone on there and call it a day.
Nope, 3.25" at the MAF.
Last edited by Terminator2; Jan 8, 2010 at 09:13 AM. Reason: Automerged Doublepost
There isn't an intake for this car that doesn't make the A/Fs go grazy out of whack.. only way around it is a tune no matter what intake you go with
That is what I thought....I have the Stage one tune in my room if I get that and then make this intake will my AFR's still be crazy?
i miss the sound of my dejon intake, i can see the satisfaction over custom fabbing one. i just felt like my car drove noticably worse with an untuned aftermarket intake then with the stock airbox with an airbox mod.
but the sound on a daily driver car makes it alot more fun to just drive your car to and from where you gotta go everyday. miss the **** outta it
OrangeCoba
Sep 25, 2015 06:06 PM
