Custom LNF ECM- What Features Should Be Added?
Old Dec 1, 2012 | 03:50 AM
  #76
paintballerr78's Avatar
Man you guys are literally gonna be getting all my money next year if this comes out around may
Old Dec 2, 2012 | 05:42 PM
  #77
Omnigear's Avatar
up =p
Old Dec 3, 2012 | 04:17 AM
  #78
silverbullet08's Avatar
Originally Posted by silverbullet08
I have most of the cars ive tuned set up like this already. Its simple. Just move the iat2 sensor wire from the lower map to the upper map on the manifold. On my set up when my IAC kicks on the E85 drops iat temps a good 20* so its simple to tune for.
This could be improved by implenting a multipler table off of the new AIC table that is active only when the AIC/meth is spraying. Which leads to another table that would be nice and simple.
The extra gm solenoid on the manifold that controls the BOV has some potential. I have used it as a nitrous solenoid controller based on boost but it is limited. We need to expand the bov solenoid controll table to a larger 3d table then give it a multiplier table for spark. This would be a perfect meth/nitrous/AIC/ or anything you want triggered based on boost. If whoever is designing the OS could verify that the address look up is to the manifold MAP PID that would be amazing. You could even use it as a secondary ebc so we could max torque to gear tables and allow true wot in first gear. Would make launching much smoother. This would be a true boost by gear set up. Not a "torque/load" by gear.
A DAL by gear.
Maybe wastegate DC by gear.
A engine run time after ignition is turned off table would be nice. Basically a "turbo timer".
Like already stated switchable map set up. Wether it be cruiz control, traction control, or a switched power input . Lol starting to sound like "Tephra". Possibly we could get some help from him? He has done wonders for the evo community.
Alternate injector constant table for E to 93 switching.
I know all these wont work but it gets your head thinking. Sure yall can branch off one of those ideas to make it better.
Yall working on this stuff still? Any of these above ideas help out? What's the eta on any of this? Working with trifecta to design this?
Old Dec 3, 2012 | 04:48 PM
  #79
1Shotwonder's Avatar
Def. fix the launch control to be adjustable.....
Old Dec 4, 2012 | 01:08 AM
  #80
BEG4MRC's Avatar
ghost cams
ghost cams my 5.0 car has that but not my lnf cobalt i would also like a 2 step that builds boost not the one gm gives u it sucks
Old Dec 15, 2012 | 04:19 PM
  #81
Omnigear's Avatar
Bumpagdz
Old Dec 15, 2012 | 05:06 PM
  #82
cdnite's Avatar
I wants!!!! Maybe Santa is real and we will get this!!!!!!!!!!
--Christian
Old Dec 15, 2012 | 05:42 PM
  #83
ULWizSS's Avatar
With just the GM3 two step version i could build about 3-4 at the line. With the wotbox i was about 8-10.
Definately keeping track of this stuff.
Old Dec 16, 2012 | 04:58 PM
  #84
etnies's Avatar
Ive already arranged for a custom tune but id love to be able to go past 7400rpm
Old Dec 16, 2012 | 10:26 PM
  #85
jacream_booSSted's Avatar
yeahhh that ethanol sensing/adjusting feature would be hellanice. lol
Old Dec 18, 2012 | 11:28 AM
  #86
gone_in_10_sec's Avatar
if someone can incorporate the fuel line Ethanol sensor (on the LHU/LDK its a black fuel sensor connected to the fuel line- under the car on the passenger side) since its a GM part instead of using an unknown ethanol fuel sensor, then its possible to "import"and use the ethanol-tables from LHU/LDK into the LNF files..
from what I've seen (using GDS and comparing with HPT), most of the "main" (MAF/MAP/Rev/boost/fuel/tq/load/etc..) LNF and LHU/LDK tables are "almost the same" for the most part, except for a few odd tables (don't know what they are - HPT should figure these tables out), these are not the same, for an example - on the exhaust cam phase tables - most of the numbers are off by ą5-22% compared between the LNF & LHU/LDK tables?? - b/c "cooler EGT or new VVT tech" maybe..
once someone figures out how to incorporate the fuel line Ethanol sensor, then its game on for the LNF..
going off on a tangent here, but I wonder if anyone has thought of using LHU/LDK file on top of the LNF file?? like the Trifecta/HPT combo/ layered tunes? - the things that make you go hmmm...
other than that - FasterIsBetter, ULWizSS, silverbullet08 & Omnigear = these are fcukin great ideas!! bravo gents.
Old Dec 18, 2012 | 09:53 PM
  #87
Matt M's Avatar
We are going to try to put together a flex fuel setup. No promises, though. No need for so and so to come in spouting vaporware...
Old Dec 18, 2012 | 09:57 PM
  #88
Matt M's Avatar
They use completely different hardware and the files are nothing alike, so that wouldn't be possible.
Old Dec 18, 2012 | 10:20 PM
  #89
ThexGovenor's Avatar
If you do the Ethanol sensor, make it for the LSJ as well lol.
Old Dec 18, 2012 | 10:28 PM
  #90
Omnigear's Avatar
Dont need sensor if dey make the tables ala flex fuel cars
Old Dec 19, 2012 | 10:03 AM
  #91
the software/hardware is similar..
Old Dec 19, 2012 | 07:27 PM
  #92
Stamina's Avatar
The Bosch E69 used in the LNF is only used in the LNF and LLT (V6 Camaro) to my knowledge. I'm pretty sure the LDK/LHU use Delphi ECMs, which operate completely differently.
Old Dec 19, 2012 | 08:14 PM
  #93
i know what your saying, should have proof-read myself.. lol.. what I meant to say, was both the LNF & LDK/LHU are a similar setup.. as in software and hardware..
got to lay off on the mint chocolate xmas Hershey's Kisses.. "sugar high" ate a 2lb bag in a hour yesterday..
Old Dec 19, 2012 | 08:42 PM
  #94
Omnigear's Avatar
Different hardware different os?
Old Dec 20, 2012 | 12:05 AM
  #95
09BlueBaltSS's Avatar
But the same
Old Dec 20, 2012 | 12:07 AM
  #96
Omnigear's Avatar
Originally Posted by 09BlueBaltSS
But the same
Os?
Old Dec 20, 2012 | 12:09 AM
  #97
Os?
Operating system?
Old Dec 20, 2012 | 10:03 AM
  #98
Omnigear's Avatar
Operating system?
Yes
Old Dec 20, 2012 | 10:34 AM
  #99
northvibe's Avatar
How do you know they are running the SAME OS on different hardware? Have you written any code for either or dissected a ECU? Just because some tables may be similar does not mean the OS or what runs on the hardware is anything close to similar.
Old Dec 22, 2012 | 08:59 PM
  #100
08VRSS's Avatar
Atleast speed density please, but ideally should be modeled after the turboxs UTEC, uses a crossover point set by throttle plate opening % to switch from MAF to speed density. That was by far the best mod when i was tuning subarus, an old ass UTEC with speed density, ignition cut launch control, amazing flat foot shifting (much better than the SS), and it had the ability to switch tuned maps to to 5 different ones, a no start tune, and a valet tune, all on the fly. THATS what i'd like to see and something i would pay for.
