Downpipe...
Old Feb 26, 2010 | 03:01 PM
wantedSS/TC's Avatar
^^ bingo. didn't read prior posts to your question. when the car was hooked up to the scanner you can see it retard timing, hell, I can see it on the RPD. It's not rocket science people!
Old Feb 26, 2010 | 03:04 PM
09BlueBaltSS's Avatar
Thank you. Debadged just isnt seeing what im trying to say I guess
Old Feb 27, 2010 | 05:37 AM
208REV's Avatar
The waste gate is not open... you can still build boost when it is in cat warm up mode, if the waste gate were open, you would not be able to as the exhaust gasses would be bypassing the turbine.
The waste gate is actuated by boost pressure on a diaphragm on a rod that opens the flap for the internal waste gate, you wouldn't be opening the waste gate during the cat warm up stage because there is not any boost pressure to open it up, messing with the timing, now that is another story.
Old Feb 27, 2010 | 12:53 PM
If you touch the gas during cat warmup it aborts the process. How are you building boost without touching the gas pedal?
Old Feb 27, 2010 | 04:45 PM
tom.g's Avatar
Exactly
Old Feb 28, 2010 | 05:30 AM
208REV's Avatar
Exactly, because you aren't building boost, your waste gate actuator is not open, it may be pulling timing for the later burn to heat the cat, but it is just going through the turbo just like normal.
Old Feb 28, 2010 | 05:50 AM
IhaveReturned's Avatar
Originally Posted by DebadgedBALT77
no its not. point blank. its not any louder running an external wastegate during idle. That is a fact. It wont sound any diffrent at all.
What the OP is asking for is also called a screamer pipe.
It sounds nothing like a normal setup with an EWG and is A LOT LOUDER.
Performance is minor, helps lag a bit.
http://www.torquecars.com/tuning/screamer-pipes.php
http://www.jperformance.co.uk/nissan...ipe-p-236.html
http://www.youtube.com/watch?v=eoO3en_eUzI
Old Feb 28, 2010 | 11:32 AM
DebadgedBALT77's Avatar
exactly. you cant be building boost without a load on the motor. i dont care if its retarding timing or not. no load- no boost. especially at idel.
im well aware at what its called. i know it louder, but it wont be loud at idel. it just wont. without boost, that wastegate wont open and it will sound just normal when driving around when not in boost.
Last edited by DebadgedBALT77; Feb 28, 2010 at 11:32 AM. Reason: Automerged Doublepost
Old Feb 28, 2010 | 01:38 PM
tomj77's Avatar
if u watch ur boost gauge in cat warmup u are very close to building boost. iv even seen it building 1 psi, so not ur wastegate is not open all the way.
Old Feb 28, 2010 | 02:31 PM
fakameanrepresent's Avatar
i want something like that.
Old Feb 28, 2010 | 03:18 PM
  #36
terry11's Avatar
You could just go external and dump off of that
Old Feb 28, 2010 | 04:10 PM
  #37
My bad, I misread.
Old Feb 28, 2010 | 06:31 PM
  #38
My bad, I misread.
alll good. yea, itll be loud as hell when your into boost, and the wastegate opens, other then that it wont be "loud" at all. ( depending on exhaust mods of course)
Old Mar 2, 2010 | 02:51 AM
  #39
208REV's Avatar
So if that is something you would be interested why don't we get a list going of people who would support this kind of mod, who knows maybe with enough people interested we might get a vendor to produce a few for us..
Old Mar 2, 2010 | 04:10 AM
  #40
Good luck.
Old Mar 14, 2011 | 04:14 PM
  #41
JacBlackSS/TC's Avatar
i have been searching for one for our cars.......my friends with evos and subbies always tell me to get a ewg or dump tube, but i realized we don't have the support for that mod
Teetzel
Jul 13, 2015 12:13 PM
Joe22
Jun 7, 2015 06:06 PM
cobalt_sport08
Dec 28, 2013 01:03 PM
SCobalt
Dec 2, 2013 09:38 PM
jhop16
Sep 19, 2010 05:40 PM
