FTW-k04R vs ZFR In need of turbo swap!!
Old Sep 9, 2016 | 12:30 AM
  #2476
Could be i mean im going over a mountain with signs that say 8% steep so yeah lots of load on the car, I could drive without getting boost but the car starts losing speed.
Never noticed it until almost the end before i replaced my stock turbo(didn't take that path that often) and it was doing that and when i installed the R it wasnt any different so i figured it was normal could be wrong
Old Sep 9, 2016 | 12:33 AM
  #2477
KMO43's Avatar
Well ya that's how the higher pressure canisters work. I have tuned a 4psi, 14psi, 20psi, 23psi and 32psi actuators. and you have to change the WGDC when changing the spring pressure. It's the whole point of changing the canister
Old Sep 9, 2016 | 02:08 AM
  #2478
T-Man's Avatar
I understand all that... My question was whether I went too aggressive on the preload, which may be the case. We'll see
Old Sep 9, 2016 | 02:10 AM
  #2479
T-Man's Avatar
LOL I'm not talking about mountains bruh. Just the lovely hilly terrain our highways have. For what you're describing, I would expect to go into some boost with CC on.
Thanks for chiming in anyway man
Old Sep 9, 2016 | 02:37 AM
  #2480
KMO43's Avatar
I maxed it out on my R plus my actuator mod held 28psi to 7k easy. Didn't notice any issues the most common would be boost creep up top because the WG isn't opening enough at WOT to control boost
You could always send me ur tune and I can see if anything pops out at me.
Old Sep 9, 2016 | 08:23 AM
  #2481
Ahh that makes more sense lol
Old Sep 9, 2016 | 08:36 AM
  #2482
63 Nova SS's Avatar
Going up a hill loads the car and can spool the turbo it's totally normal has nothing to do with ramp. Ramp is % of max torque vs rpm. 1 to 5psi of light boost up a hill will have nothing to do with ramp
I guess it depends on how fast you want to climb the hill and how steep it is. I purposely try to stay out of boost most of the time so I accelerate to accommodate that. I baby mine more than drive it like I stole it. I've found that if I get on it all the time it starts to feel slow plus it is harder on the drivetrain. If you stay out of the throttle more, when you do get on it, it feels pretty good, and faster than you thought it was.
Old Sep 9, 2016 | 09:42 AM
  #2483
To what I've seen my car likes to be abused lol not that i abuse it but when i do drive it aggressive or go wot and stuff it feels like it runs better
Old Sep 9, 2016 | 12:02 PM
  #2484
T-Man's Avatar
That would be cool, thanks man
I typically just set the CC and run with it. I don't typically drive my car(s) too hard but when I do, I drive them like they owe me money.
I agree with this, car does like aggressive driving
Old Sep 9, 2016 | 12:13 PM
  #2485
KMO43's Avatar
No problem
Old Sep 9, 2016 | 06:50 PM
  #2486
T-Man's Avatar
Welp, it wasn't the preload on the WG. Took out 3 full turns of preload and it made zero difference.
Old Sep 26, 2016 | 10:07 PM
  #2487
KMO43's Avatar
We're getting some good results from Shaun's car so good I turned the boost down and timing is still going up!!
Old Sep 27, 2016 | 12:21 AM
  #2488
KMO43's Avatar
Shaun is on 91 plus 1000cc meth which is a ton but has super low EGTs and ran a 3.014 75 to 100 and to compare Colin ran a 3.196.
I think running meth in the intake stream helps cool the intake charge better and spraying that much keeps the R so cool it can do very well. If anybody was to run meth and E on an R I'd expect to see some great numbers!
Old Sep 27, 2016 | 07:47 PM
  #2489
Canadia's Avatar
Shaun is on 91 plus 1000cc meth which is a ton but has super low EGTs and ran a 3.014 75 to 100 and to compare Colin ran a 3.196. I think running meth in the intake stream helps cool the intake charge better and spraying that much keeps the R so cool it can do very well. If anybody was to run meth and E on an R I'd expect to see some great numbers!
Shaun's car is working great since you tuned him for meth. Will be on the rollers oct 14-16 at a local mustang dyno day!
Old Sep 27, 2016 | 08:10 PM
  #2490
KMO43's Avatar
Thanks! I told him the whole time that turbo likes being cool I'm happy it's working out great!
Old Oct 19, 2016 | 11:54 PM
  #2491
CaRRiED's Avatar
So what kind of power does this thing max out at?
Old Oct 20, 2016 | 02:31 AM
  #2492
LNFwagonSS's Avatar
Originally Posted by CaRRiED
So what kind of power doea tgis thing max out at?
Enough to run 11s
Old Oct 20, 2016 | 10:56 PM
  #2493
CaRRiED's Avatar
Originally Posted by LNFwagonSS
Enough to run 11s
I like that answer lol
Old Nov 23, 2016 | 01:55 PM
  #2494
FLASH1970's Avatar
I'm glad I stumbled upon this FTW-K04R info... just did a front mount and noticed my turbo had a 'lil play in it. The car has 130K on it so it's been in the back of my mind that the turbo will soon need a rebuild/upgrade.
Old Nov 23, 2016 | 02:23 PM
  #2495
You should get one I'm sure turbobay will have a sale on them or zzp will have the k04 or zfr on sale
Old Nov 23, 2016 | 02:31 PM
  #2496
Devin86's Avatar
450 for a k04r with coating for free for black Friday from turbo bay is what FB said
Old Nov 23, 2016 | 02:40 PM
  #2497
FLASH1970's Avatar
yeah yeah... I saw that. liked the fb page, messaged him. my gsx might 'need' an upgraded td04 turbo too.
Old Nov 23, 2016 | 02:44 PM
  #2498
Or if I get my zfr I'm might be selling my ko4r in the near future
Old Nov 23, 2016 | 03:15 PM
  #2499
FLASH1970's Avatar
I'm waiting to see what he says about time frame, how much for a 14b/16g upgrade as well on a different turbo... if I can get the k04 done before it gets too cold out I might do that just so it doesn't crap out on me in February. With my luck, wouldn't surprise me at all if it did.
Old Nov 24, 2016 | 10:18 PM
  #2500
no_ss's Avatar
2.997sec 75-100mph to keep this updated.
