FTW-k04R vs ZFR In need of turbo swap!!
Old Dec 4, 2016 | 01:09 AM
  #2526
no_ss's Avatar
Well, 4.39sec 60-100mph, 2.95sec 75-100mph on the R and E85.
Old Dec 4, 2016 | 04:52 AM
  #2527
KMO43's Avatar
Sounds slow
Old Dec 4, 2016 | 01:57 PM
  #2528
LNFwagonSS's Avatar
Ive got a stock new ldk head I would sell cheap if your interested.
the problem is everyone who professionally ports the lnf head will only work with a new head. Zzp & Pwerks specifically. I'm probably gonna get the ZZP head. It seems they have had the most experience on this head. I have a local guy(nick smithberg) who will do it but that will require a R&D test head or two which will be more expensive in the long run. I'm all about R&D but I think I'll leave this one to the experts.
Pretty damn good. I was just under 5sec 60-100 on stock turbo(420wtq) and 4.45 gears. Are you using 4.05s?
Old Dec 4, 2016 | 02:12 PM
  #2529
KMO43's Avatar
He's 3.82
Old Dec 4, 2016 | 02:21 PM
  #2530
63 Nova SS's Avatar
Originally Posted by KMO43
He's 3.82
Running full e and the R.
4.45 gears on the r ,+, or stock get you out of the efficiency of the turbo having to spin to 7300 to get to 100mph. Yeah the r keeps up better than stock but it's dropping power at 7300.
Old Dec 4, 2016 | 03:11 PM
  #2531
YelCal7's Avatar
What kind of clutch you guys would recommend using ? I was thinking either gmpp or ky stage 3+ ?
Old Dec 4, 2016 | 03:13 PM
  #2532
KMO43's Avatar
Southbend stg 4
Old Dec 4, 2016 | 04:38 PM
  #2533
63 Nova SS's Avatar
How much torque are you expecting to put through it? Big difference in price between the gmpp and all the rest. How long do you want it to live for?
Old Dec 4, 2016 | 05:45 PM
  #2534
YelCal7's Avatar
I dunno...I have equinox intake n exhaust with fueling lobe upgrade, phenolic intake manifold n throttle body spacer, k04r turbo (haven't put those in yet until transmission n clutch in 1st). Maybe getting TTR intake manifold or ported intake manifold and definitely getting 4.05 lsd transmission with it. I've heard great thing gmpp clutch n it does hold up 500hp from what I've seen some Cobalt owners surprisingly.
Old Dec 4, 2016 | 05:59 PM
  #2535
KMO43's Avatar
If u look at my 500hp dyno it has really smooth power delivery and only 427tq. The R is the exact opposite. Get the southbend
Old Dec 4, 2016 | 06:15 PM
  #2536
YelCal7's Avatar
Ah...Do you have to run zzp tob spacer to run with southbend ?
Old Dec 4, 2016 | 08:29 PM
  #2537
KMO43's Avatar
No that thing is silly 1/4 is way too much. A 1/16 would be good
Old Dec 5, 2016 | 04:15 AM
  #2538
LNFwagonSS's Avatar
I could go on for days about clutches. I wish I would've just saved my pennies and got a balanced Spec setup or the CM twin disc. KY twin disc also looks promising but heavy.
I've been running the KY stg 3 for 4ish years now. I've sent it back to KY to be serviced/remanufactered twice (for a fee) because of slipping but I don't take it easy on the clutch. 2nd gear burnouts, 6k sidestep launches @ 7psi on slicks, and NLS all the shifts. This last one they made for me now has an ET record and several 1.7 60' lunches under its belt. The clutch disc has two different materials on each side of pucks unlike the previous ones. In the end its a cheaper clutch, you get what you pay for. KY took care of me when I needed it but was a PITA to deal with. I just need a better clutch for what I do with the car.
Sry yelcal, just seen you said ky stg3(+)... It's a less agressive clutch than the regular stg 3 with less tq capacity and less bite.
Old Dec 5, 2016 | 05:27 AM
  #2539
63 Nova SS's Avatar
I would hate to daily your clutch by the sounds of it......omiotec always said the balanced spec 3+ clutches were good. For drag I would imagine the twin disks would be the way to go but the trans better be strong.
The gmpp is a good clutch for the money but depending on driving style I'm not sure how long it will take the abuse. I put probably 15-18 passes on mine at the track this year along with 2nd gear burnouts and so far it's held up well. I'm not expecting it to last forever though.
Old Dec 5, 2016 | 07:15 AM
  #2540
YelCal7's Avatar
Hey Folks, did you guys know anything about f23 transmission swap ? I'm reading in Cobalt SS Gang and guys are talking about it n saying it's stronger than f35 transmission.
Old Dec 5, 2016 | 11:54 AM
  #2541
Area47's Avatar
Rent me! per hour
keep in mind clutches are rated on torque capacity, not hp.
Old Dec 5, 2016 | 12:43 PM
  #2542
KMO43's Avatar
That was my point. My car makes the same TQ as a R probably but it comes in way smoother so is easier on parts
Old Dec 5, 2016 | 02:44 PM
  #2543
63 Nova SS's Avatar
Yes it can be done. There are several parts to change along with it. I've heard the trans itself will take quite a bit of power and is cheaper. The drawbacks are changing mounts, cables, adding a lsd and purchasing good axels as the f23 doesn't have as good of axels as the lnf axels were. So I've heard. They are cheaper to purchase outright though.
Old Dec 5, 2016 | 03:23 PM
  #2544
user 72239's Avatar
not to mention abundant.
Old Dec 5, 2016 | 06:31 PM
  #2545
no_ss's Avatar
I love my southbend.
Old Dec 5, 2016 | 10:16 PM
  #2546
LNFwagonSS's Avatar
I call dibs on his lnf axles if he f23 swaps
Old Dec 6, 2016 | 12:23 AM
  #2547
no_ss's Avatar
Driving the R really is fun honestly. I know its not the fastest but its still a good turbo to have a good time with.
Old Dec 6, 2016 | 10:36 AM
  #2548
Canadia's Avatar
Well I caught the seller of the GMPP clutch and flywheel I bought and switched my order to just the flywheel as I found a KYS3 for fairly cheap.
So I'll be going that route.. only thing is he also has a 6758 with 5k miles on it and he'll sell me both the new KY and zfr for 1300usd
Old Dec 6, 2016 | 10:49 AM
  #2549
63 Nova SS's Avatar
Originally Posted by Canadia
Well I caught the seller of the GMPP clutch and flywheel I bought and switched my order to just the flywheel as I found a KYS3 for fairly cheap. So I'll be going that route.. only thing is he also has a 6758 with 5k miles on it and he'll sell me both the new KY and zfr for 1300usd
Yeah I saw that too, that's a good deal
Old Dec 6, 2016 | 10:55 AM
  #2550
Sounds like a good deal
