Good turbo upgrade for lnf
Old Aug 16, 2011 | 04:47 PM
  #51
Boosted4's Avatar
Originally Posted by gdubs
Tuning went great! This thing is a F***ING MONSTER. we are hitting 26psi! and then stepping it down to 24.5 in the higher RPM. We have advanced the timing and increased the power in the mid band quite a bit.
The turbo pulls, and pulls, and pulls, and pulls, all they way to 7k with out any drop off at all like the stocker used to do.
Also the sound on the turbo is retarted! its so loud. The sucking noise sounds like a jet engine! (not really) but its really really loud.
And yes this is a ture bolt up application.
I will be writing a tread on thursday or friday with all the info. Including dyno graphs if i can get time on the local dyno here.
Good to hear. May be picking up one of these really soon if all goes well with yours!
Old Aug 16, 2011 | 09:30 PM
  #52
vahdyx's Avatar
Depending on how Vince tunes me I may get one too. If I need to schedule a dyno day that will suck. I will if I have to I guess
Old Aug 16, 2011 | 10:09 PM
  #53
MS3 2 SSTC's Avatar
Subd for results. If it goes well I might end up getting this.
gdubs are you on the stock clutch or do you have an upgraded clutch?
Old Aug 16, 2011 | 10:53 PM
  #54
Fastgti69's Avatar
Sick ass! I'm down for the thread and dyno results!
Old Aug 17, 2011 | 01:52 AM
  #55
gdubs's Avatar
Stock clutch
Old Aug 17, 2011 | 02:15 AM
  #56
Garing7's Avatar
any numbers yet gdub?
Old Aug 17, 2011 | 07:41 AM
  #57
gdubs's Avatar
Not yet. My local dyno is busy getting ready for an event this week. Most likely next week
Old Aug 17, 2011 | 08:09 AM
  #58
MS3 2 SSTC's Avatar
Stock clutch
Hows it holding up? Any slippage?
Im still torn on which clutch to buy.
Old Aug 17, 2011 | 11:17 AM
  #59
gdubs's Avatar
Holds perfect. No slip at all. 30k miles
Old Aug 17, 2011 | 12:30 PM
  #60
MS3 2 SSTC's Avatar
Thanks for the reply!
Old Aug 17, 2011 | 02:37 PM
  #61
FasterIsBetter's Avatar
Lucky. Mine slips pretty bad in 4th and 5th.
Old Aug 17, 2011 | 09:44 PM
  #62
cobaltssoverbooster's Avatar
just corrected 4 tunes from vince here in florida and they were all running 12.1 afr and a max of 12* timing???? he even went as far as running a pte turbo setup at 11.8 afr with only 5* timing. so you should all be very carefull with his tunes id hate to see anyone hydrolock their motor because he tuned it way to rich.
Old Aug 17, 2011 | 09:55 PM
  #63
HHRSSouth's Avatar
Any reason everyone is getting back on the K04+ band wagon?
There wass a reason everyone said it wasn't worth the $1k it cost for the wheel upgrade.
Waiting for results, maybe you will prove me wrong (tuning has come a long ways from back when these first were tested).
Old Aug 17, 2011 | 09:59 PM
  #64
vahdyx's Avatar
What do you mean you corrected his tune? I think I was 12.0 AFR and not sure the timing. Why is that bad. Also if the number is higher is that better? So if I'm 13 am I rich or lean?
Old Aug 17, 2011 | 10:03 PM
  #65
the lnf's run best power between 12.6 and 12.8 afr
14.7 is stoich the higher the number the leaner it is, the lower the number the richer.
anything bellow 12.4 on a lnf turns it into a deisel wanna be leaving you sooting around town making shitty power and wasting unnecessary gas.
and i actually ended up redoing the cams, fueling, timing and some torque related stuff they were really messed up. idk what hes doing but he wasnt helping these people service wise verry much either...denying they ran little timing, and refused to raise it and fuel ratio. he mave have unlocked stuff but i dont think he knows what some of it does either.... im not him so idk exactly whats goin on
HHRSSouth
well it is easier to tune out the surge spot it has....
i still dont think its a super great idea the journal in the one i had blew in about 3 months.
Old Aug 17, 2011 | 10:52 PM
  #66
brant's Avatar
lol just get what i did 58/57 precision turbo... i made over 450whp on the dyno and bolts right on
Old Aug 18, 2011 | 12:44 AM
  #67
gdubs's Avatar
HHRSSouth
Stop bashing Vince at TrifecA AND GET THE **** OUT OF THIS THREAD. hes tuned more LNFs and other GM vechs in 1 month than u will in your life. And the GM vehs hes has tuned have more miles logged with out engine problems from the tune.
He also has hard data and dyno graphs that hiss method of tuning provides more power at the wheels.
SHUT THE **** UP. its immature to bash your competition. shut up and keep your comments out of a thread that has nothing to do with trifecta
  #68
MS3 2 SSTC's Avatar
I'm hitting 12.5~12.9 on his aggressive tune. Haven't ran into issues yet when I got WOT
Nicely said
Last edited by MS3 2 SSTC; Aug 18, 2011 at 12:44 AM. Reason: Automerged Doublepost
Old Aug 18, 2011 | 12:45 AM
  #69
gdubs's Avatar
Its because no one provided hard data and based it all off 1 thread on a solstice forum
Old Aug 18, 2011 | 01:43 AM
  #70
Garing7's Avatar
does the 5857 precision turbo bolt right up? Or do you have to customize parts or buy a kit? And what were you all running that you were making 450 hp?
Old Aug 18, 2011 | 01:45 AM
  #71
Garing7's Avatar
gdubs tried emailing Performance Autowerks with some questions about the k04+ and no response. Did you call them or email them? Because i couldnt find a number for them.
Old Aug 18, 2011 | 02:25 AM
  #72
Fastgti69's Avatar
x2
did you just buy the turbo and bolted right onto the stock exhaust manifold? I'm sure you had to fab a new intake and downpipe...
that guy needs to explain lol
Old Aug 18, 2011 | 02:29 AM
  #73
Boosted4's Avatar
I did the same thing, sent them an email concerning the K04+ and received no response as well. This was about 3 weeks ago.
On a separate note, I'd just like to add my car has been running a Trifecta tune since about 3k miles to the 28k I have now. No problems whatsoever. I also have about 3k miles on my car since I received an aggressive retune from Vince, of which the AFR appears to be 12.5-12.7 at WOT. No problems here whatsoever.
To all you clowns posting about how a Trifecta tune "had this guy's car messed up, had that guy's car messed up, with horrible data logs" etc etc. If you personally have not experienced these issues with YOUR OWN vehicle, I'm not too interested in these alleged third party issues.
Old Aug 18, 2011 | 03:17 AM
  #74
gmtech16450yz
Guest
Posts: n/a
Clown here...
Anyone that refers to the fuel mixture on an LNF in terms of AFR shows they do not understand much of anything about the Bosch E69 ECM. Especially if they're trying to run Ethanol.
Oops, gotta go, the Ringmaster just told me the elephants are eating my bowling pins.
Old Aug 18, 2011 | 04:04 AM
  #75
Boosted4's Avatar
Originally Posted by gmtech16450yz
Clown here...
I just checked every single post in this thread, and theres ZERO mention of running Ethanol. I think you have this thread confused with the other Trifecta bash thread, which is titled "trifect air fuel ratio."
