Good turbo upgrade for lnf
Around 1100$, keep in mind we in Puerto Rico...have 93 oct but our gas doesn't have the 10% ethanol US gasoline has, so we are limited by this fact. Car is at 27 psi with only 15* of timing up top, plenty of space to work with, if we were to have the right fuel.
Sent from my iPhone using CobaltSS
Still ZFR is 2k+ in pricing and still no car with good enough numbers at same psi/octane...E85 maybe good for 500hp but what good it does if you only have 94oct...still 2k+ bolt ons...for maybe...20 to 50HP more? Not good enough in my opinion, you don't need to maf relocate if don't want to and you don't need to to recirc if you don't want to...all that can be tuned for.
With 94oct you will hit 400hp mark easily and it won't break your bank account.
It is not a fact of not liking...but as you just said...any turbo on the car will still peak out at 400-430...then why pay more for a turbo that you will not use...yes ZFR will outflow the others, but still you stay at the same 400-430 range...not worth 800$+ if I'm not going to go behond these numbers.
ZFR 1900
BNR and 20g is like 1200? plus charge pipe and bov, another 400. so about 1600 at the least! compared to 1900. The extra 300 dollars is worth the titanium gamma turbine, dual ceramic ball bearing and a billet wheel. And the way it spools is just like stock. For people who want stock like spool with over 100 hp over the power band of stock turbo, this is the way to go. Esp if you canyon and stuff, you'll need better spool etc. Still though, I have a 25g now so I've gone through both kits pretty much.
True, but we're both going to start from stock cobalt SS to a big turbo right?
ZFR 1900
ZFR 1900
