Had no F'in idea!!
Old Sep 8, 2012 | 03:04 PM
Cobalt_Nation08's Avatar
Had no F'in idea!!
So I'm looking to get a new clutch for my '08 SS/TC. A stage 3 KY from TTR is $530 w a TOB... not bad @ all, but then I call my local Chevy dealer to get a quote on a flywheel... WTF!!! $713.64!!!! I don't want to have the trans pulled to replace the clutch, and just resurface the flywheel. Resurfacing feels a l'il half- assed to me when it comes to the trans so... Can I get some help on where to look for a flywheel plz!!
Old Sep 8, 2012 | 03:08 PM
carstedt's Avatar
i got a OEM one from zzp when i did mine
Old Sep 8, 2012 | 03:14 PM
Chevycobaltss3's Avatar
Order the Lsj flywheel from ced
FrossB's Avatar
Thread Killer
Resurfaced mine. It was fine. But ZZP sells OEM flywheels. Im sure other vendors do as well
Old Sep 8, 2012 | 03:25 PM
AARON-SS-TC's Avatar
why do a lsj?????
Anyways, go to zzp and they have oem flywheels for $120
Old Sep 8, 2012 | 03:32 PM
Sox-Fan's Avatar
Got Brakes?
What causes you to feel as though refacing a flywheel is half assing it?
Old Sep 8, 2012 | 04:10 PM
SSlobalt's Avatar
Originally Posted by AARON-SS-TC
why do a lsj?????
This. I don't know how they offer them so cheap, but they do.
Old Sep 8, 2012 | 04:15 PM
BlackLsCoupe's Avatar
i can get OEM for $90 i think it was. thank you grandfather. my base total clutch and flywheel was $280
Old Sep 8, 2012 | 05:33 PM
Nfamous60's Avatar
have a clutchmasters flywheel im selling
Old Sep 8, 2012 | 06:41 PM
Frogstofall's Avatar
They are different fyi for those that don't know.
Old Sep 8, 2012 | 06:46 PM
09CobaltSS1's Avatar
^^That was always my understanding as well. Otherwise, why sell them as a lnf or lsj specific flywheel?
Old Sep 8, 2012 | 06:49 PM
^^^ lol. I have an LNF. Didn't think an LSJ flywheel would work. Thanks for all the info so far.
Old Sep 8, 2012 | 07:37 PM
SSlobalt's Avatar
I asked the same question about the TOB. I never got a good answer, btw.
Old Sep 8, 2012 | 08:18 PM
tomj77's Avatar
i have a question, why is the zzp oem so cheap?
Old Sep 9, 2012 | 12:08 AM
Ch1ck3n's Avatar
Pretty sure zzp sells clutches that are either pulled from cars they work on, or they get them at cost and just don't mark them up like dealerships do..
Either way, zzp was the route I went when I installed my Spec 3+ and I am pleased with my decision.
Old Sep 9, 2012 | 12:10 AM
SSlobalt's Avatar
I don't know and I don't care
Old Sep 9, 2012 | 11:52 AM
Matt M's Avatar
lol, no, they are new flywheels.
Old Sep 9, 2012 | 05:59 PM
tomj77's Avatar
why are they so cheap compared to every other place u can find em?
Old Sep 10, 2012 | 01:40 PM
Pepsi's Avatar
you can just machine yours. It really is no difference
Old Sep 10, 2012 | 02:53 PM
soundjunky's Avatar
^^what he said.
So do you insist on replacing your rotors with every brake job too?
if there is nothing wrong with the friction surface, there is no reason why machining it won't suffice - all you're doing is cutting it down to make the surface perfectly flat again... same idea as turning a rotor.
The only time where replacing the flywheel is necessary is when it has been cut enough times to put it out of spec ~ thereby placing the clutch assembly closer to the rear of the block, and far enough that the TOB won't be able to do it's job...
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
Rduncanss06
Sep 27, 2015 11:17 PM
