help, no boost
help, no boost
was driving home one night and noticed i wasnt boosting over 5lbs, normally i would think limp mode, but theres no CEL or pending codes, if it were a bad MAF sensor it would throw a code correct? im HP tuned by a local guy here in long island, he says its not the tune but something else ?????
yes it can. i had a small boost leak for a while. turned out i forgot to tighten a hose all the way down... and after about a month it got worse and probably only losing 1-2psi at WOT, and after a while it would throw the car in limp mode and get 5psi. and when i drove it WOT in 5psi it would go down to 0psi lol....
Often times a blown intercooler. Seams on the sides are known to pop.
Not saying that's definitely your problem but I've seen it happen a few times. Definitely sounds like a boost leak either way.
what psykostevo said is correct as well..
even a small hairline crack on the fmic can give you 5psi or less
Did you check by doing a proper boost leak test? visual/by hand doesnt cut it. You have to put pressure (15-20psi) and hold it there and spray soapy water or leak tester (Snoop is a brand my work uses, not for cars but mining processing, dont want deadly gases leaking at fitting). IIFC there is a thread about how to perform a boost leak correctly.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
