help, no boost
Old May 7, 2013 | 08:23 AM
blk06ss/sc's Avatar
help, no boost
was driving home one night and noticed i wasnt boosting over 5lbs, normally i would think limp mode, but theres no CEL or pending codes, if it were a bad MAF sensor it would throw a code correct? im HP tuned by a local guy here in long island, he says its not the tune but something else ?????
Old May 7, 2013 | 08:33 AM
Did you do a boost leak test?
Old May 7, 2013 | 08:49 AM
user 72239's Avatar
Pull your battery. see if that fixes it. i had the same problem before and I had to pull my battery. Could also be a bad vacuum tank
Old May 7, 2013 | 12:02 PM
blk06ss/sc's Avatar
Did the battery didn't help, next is boost leak, but would a boost leak really cause it to lose 20lbs of boost ?
Old May 7, 2013 | 12:12 PM
user 72239's Avatar
Usually it makes the car run like complete **** but not limit you to 5 psi unless you had a massive leak.
Old May 7, 2013 | 12:29 PM
Is your BPV connected? IIRC the BPV not connect limits you to 5-7psi. Check all your lines and ensure they're connected properly.
Old May 7, 2013 | 12:35 PM
user 72239's Avatar
Yes check your BPV. Make sure nothing is torn. a leaking or bad check valve on the vacuum tank will cause this issue too
Old May 7, 2013 | 01:14 PM
Terminator2's Avatar
It is on WG spring pressure only. I would suspect either the boost solenoid is stuck open leaving the WG constantly open, the BPV diaphram is leaking badly, or the check valve in the vac tank for the BPV is bad.
Old May 7, 2013 | 01:17 PM
damastah's Avatar
yes it can. i had a small boost leak for a while. turned out i forgot to tighten a hose all the way down... and after about a month it got worse and probably only losing 1-2psi at WOT, and after a while it would throw the car in limp mode and get 5psi. and when i drove it WOT in 5psi it would go down to 0psi lol....
Old May 7, 2013 | 05:19 PM
blk06ss/sc's Avatar
i run a tial bov, with the vac line conected straight to the intake mani
Old May 7, 2013 | 05:47 PM
umrdyldo's Avatar
Are you running stock intercooler?
Sorry for a dumb question. I didn't see it on your list.
Old May 7, 2013 | 05:55 PM
damastah's Avatar
do you have the ECP tune?
Old May 7, 2013 | 06:05 PM
blk06ss/sc's Avatar
yea checked all the couplings there fine, and sry ecp? theres no selecting my tune, he made it so its always on
Old May 7, 2013 | 06:10 PM
damastah's Avatar
there is your problem...
contact vince, give him your VIN number, and let him know you want an ECP tune..
Old May 7, 2013 | 08:39 PM
user 72239's Avatar
Wonder if you had a silent code that tripped 5 psi only cause of your BOV.
Old May 8, 2013 | 01:02 AM
Psykostevo's Avatar
Often times a blown intercooler. Seams on the sides are known to pop.
Not saying that's definitely your problem but I've seen it happen a few times. Definitely sounds like a boost leak either way.
Old May 8, 2013 | 06:34 PM
damastah's Avatar
if you get the ECP tune and you still have 5psi problem...
what psykostevo said is correct as well..
even a small hairline crack on the fmic can give you 5psi or less
Old May 8, 2013 | 06:48 PM
Did you check by doing a proper boost leak test? visual/by hand doesnt cut it. You have to put pressure (15-20psi) and hold it there and spray soapy water or leak tester (Snoop is a brand my work uses, not for cars but mining processing, dont want deadly gases leaking at fitting). IIFC there is a thread about how to perform a boost leak correctly.
Old May 8, 2013 | 07:15 PM
damastah's Avatar
soapy water test sucks. just hook up a fog machine to your upper charge pipe, and make sure your throttle is closed. lol... easiest way imo
Old May 8, 2013 | 07:26 PM
Snoop def works better than soapy water, and is cheaper than a fog machine.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
