hp to boost relationship??
Old Sep 1, 2010 | 12:26 AM
cresintern's Avatar
Just curious , are boost levels related to hp? like are your highest hp levels occuring with your highest boost levels??
Old Sep 1, 2010 | 12:29 AM
Boxing Fan's Avatar
No... There's a lot more to it then that. Obviously more boost means more HP, but only if it's tuned correctly.
Old Sep 1, 2010 | 12:34 AM
EatonTVS07's Avatar
Boost is restriction in the system.
Old Sep 1, 2010 | 12:40 AM
Kyle4236's Avatar
correct me if im wrong but u could make the same power at 10 lbs in a bigger turbo and a less restrictive setup as you could in the stock setup at 20 lbs. boost is just the pressure and how hard the turbo is trying to force the air into the engine but with the stock setup it takes more pressure to force the same amount of air into your engine than a bigger turbo/ less restrictive setup. its all about how much air you can get into the engine not what pressure you sit at
Old Sep 1, 2010 | 12:47 AM
ronn's Avatar
Related..sure. But not a direct one. On my dyno, I reached Max boost quickly @3000RPM in 4th gear...that's where my Max torque peaked too. The boost held steady all the way to 6000RPM. Max HP was @ 5600RPM. Had the boost DROPPED at all, HP would not have reached the same level @5600RPM.
Old Sep 1, 2010 | 09:55 AM
Supercharged Guy's Avatar
Boost doesn't always mean more hp, theres more involed then just turning up the boost and hoping for 900hp
Getting the right Tuner, Timing, BOOST!, etc. all matters
Old Sep 1, 2010 | 07:48 PM
tomj77's Avatar
what these guys mean to say is yes, u up ur boost u will get more power, but if u dont do the other stuff like timing and such right to compliment the boost u wont get as much power as u could.
typically in little 4 bangss 1 psi = 10 hp. and if u look at what people are dynoing at 22 psi tunes and stuff, that seems to be more or less accurate. Turbo with more airflow would net u more hp per psi with supporting mods to timing and such.
Old Sep 1, 2010 | 09:22 PM
LS6Rally's Avatar
essentially yes, More boost + more power. i know these guys are refering to timing and a tune. but thats all relevant to upping the boost. if i read you question correctly your askign if you change your boost, will it effect power, simple answere, YES!
also horsepower is only a calculation of torque
(Torque x Engine speed) / 5,252 = Horsepower
if you look at dyno charts, Torque and Horsepower curves always cross at 5252 RPMs
Old Sep 1, 2010 | 09:34 PM
WickedSS2005's Avatar
boost DOESNOT = HP. I have lower boost than I have for the past 2 years and make more power. Efficiency = power....
Old Sep 1, 2010 | 09:42 PM
tomj77's Avatar
u changed somthing that gave u better airflow, add more boost now and it will = more hp, unless ur supercharger is out of efficency, then it dont work, but if its not then boost does = hp
if that wasnt the case, lets all take our turbos off cause we can make same hp either way cause boost doesnt = hp. lol come on man.
Old Sep 1, 2010 | 09:49 PM
LS6Rally's Avatar
^ exactly. if all other variablies are the same. boost = Power
Old Sep 1, 2010 | 09:50 PM
Ok dick. Take things a little too literal huh? Explain how an HPT tuned car, similar mods, similar timing etc. on 21psi made more power (a decent bit more) than it did on a custom tuned trifecta infiniboost tune making 27psi. Same components. Fueling may be a little dif but the afr's were within a few points of eachother. One make 297/324, reflash and run again, made 328hp/366tq. Less boost. Similar fuel/timing. Come on man.
Higher boost also makes more heat. Heat robs power. Upping boost is not always guaranteed power...
Old Sep 1, 2010 | 09:51 PM
LS6Rally's Avatar
well in that case. take a S/C'd 4 banger and a big block chevy for a compro. and youre right, but you didnt just drop your boost and make more power
Old Sep 1, 2010 | 09:54 PM
LS6Rally's Avatar
[QUOTE=WickedSS2005;5202587]Ok dick. Take things a little too literal huh? Explain how an HPT tuned car, similar mods, similar timing etc. on 21psi made more power (a decent bit more) than it did on a custom tuned trifecta infiniboost tune making 27psi. Same components. Fueling may be a little dif but the afr's were within a few points of eachother. One make 297/324, reflash and run again, made 328hp/366tq. Less boost. Similar fuel/timing. Come on man[/QUoute]
sounds to me like trifecta dropped the ball
Old Sep 1, 2010 | 09:57 PM
Ported head. Lowered restriction = lowered psi
Old Sep 1, 2010 | 11:23 PM
Area47's Avatar
Rent me! per hour
psi = pressure per square inch.. a measurement of resistance.
Old Sep 1, 2010 | 11:28 PM
tomj77's Avatar
well 27 psi is makeing alot more heat cause the turbo is out of efficency by a lot so alot more heat soak, more heat= less oxygen in the air charge = less power. and every car is different. alot of 27psi trifecta tuned cares make 330hp and 400tq, so i guess all those little mods u made to timing and such helped the car make that extra power.
And yes i took it literally cause u said it literally. lol explain urself better next time.
Old Sep 2, 2010 | 06:30 AM
I did explain myself the first time. Carry on
Old Sep 2, 2010 | 07:41 AM
Staged07SS's Avatar
Administrator
Administrator
Oh boy, not another boost thread
Boost = restricton
Lower restriction .... gain efficiency .... make more power !
Old Sep 2, 2010 | 11:03 AM
Chandler's Avatar
HowStuffWorks - Learn How Everything Works!
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
