LDK build thread, version 2.0
Old Apr 29, 2017 | 11:49 AM
tomj77's Avatar
Originally Posted by 08VRSS
Those valves are the result of 147,000 miles and not cleaned once, stock pcv system. Gotta love DI.
The aem e85 fuel pump is a pain in the rear, lots of modification of the fuel pump canister is required as the pump is slightly longer than the stock one and the pump plug needs the pins reversed, but got it done. LDK is all dressed and ready to be bolted to the trans.
It's all the little stuff like cleaning the engine bay re looming wiring that's taking it much longer than anticipated, I'm getting burned out but trying to push forward. Still have to fab up the down pipe and turbo intake once it's all in too.
I hear ya, I'm about to collapse already from exhaustion on my project, work 10 hours then come home and work like another 5 on the car
Old Apr 29, 2017 | 07:15 PM
08VRSS's Avatar
Yes, it is very very very exhausting. I hope it's rewarding. Ready to go back in while I lay here and die from heat stroke.
Old Apr 29, 2017 | 09:41 PM
08VRSS's Avatar
Dude you could not pay me to do that again.
Old Apr 29, 2017 | 11:24 PM
63 Nova SS's Avatar
Nice work guys. Keep at it!
Old May 1, 2017 | 06:19 PM
08VRSS's Avatar
Almost there, exhaust all fabricated and done, intake fabricated and done, now trying to figure out which wires go where lol.
the ky stage 4+ I bought from James Rakes had the same pedal feel as the stage 3 did so that's nice. Clutch all bled yesterday and new brakes on.
Almost there........
4 days so far..... 12 hours a day....... I'm mentally and physically beat
Old May 2, 2017 | 12:33 AM
08VRSS's Avatar
Well ladies and gents..... it lives!!!!!!!!!!!!!
im so happy after working on it all day today to get it done, i was very very nervous priming the engine and the moment of truth, no leaks, no problems, runs ok but I'll have to work on the tune tomorrow with the opels to go do the breakin zzp procedure.
the aem e85 pump is working great too, it does indeed need the leads reversed from factory but the factory plug plugs right in and the fuel canister where it sits needs modded. I now have a 320lph e85 pump and 6an line feeding my high pressure pump and 5th injector.
Tom was right about those radiator fan plugs , pain in the rear to plug in
Old May 2, 2017 | 12:28 PM
T-Man's Avatar
Congrats man! Looking forward to see how it performs for you.
Old May 2, 2017 | 03:52 PM
08VRSS's Avatar
Ready to tear it up....
Old May 2, 2017 | 04:05 PM
Nice man enjoy it
Old May 2, 2017 | 08:22 PM
tomj77's Avatar
Nice! How did u get the pcv on the vc to intake to fit with the wastegate there
Old May 2, 2017 | 09:51 PM
  #36
63 Nova SS's Avatar
Congrats, looks good!
Old May 3, 2017 | 09:41 AM
  #37
Was there any particular reason you switched to a braided fuel line? Thats the same size as stock and stainless hardline lasts a hell of a lot longer.
Old May 3, 2017 | 11:28 AM
  #38
tomj77's Avatar
He didn't, that's for his 5th injector
Old May 3, 2017 | 11:48 AM
  #39
08VRSS's Avatar
shorten it, tig weld it back together, and point it slightly up to clear the valve cover bolt.
Old May 3, 2017 | 11:55 AM
  #40
08VRSS's Avatar
actually I did bc it's cheaper and all my lines were rusted from Ohio winters.
Old May 3, 2017 | 01:50 PM
  #41
tomj77's Avatar
Ah I just used an an6 to 1/8 npt and tapped the hole, it fit. Had to take off wg to install it but it worked. Also had to point it up some.
Old May 3, 2017 | 01:51 PM
  #42
tomj77's Avatar
Ah ic. U guys use a lot of salt there? Idk mine seem pretty good to me and if done 9 winters. Of I ever need to I'll go same route
Old May 3, 2017 | 04:08 PM
  #43
08VRSS's Avatar
that braided stuff I used also weighs a ton lighter than the stock lines or stainless lines. Yeah I'm glad I moved to Texas, no more snow or salt. The salt ate my subframe and lca on my Subaru wrx that the lca broke in half and the subframe was rotted through. Subaru replaced both for free even with 180,000 miles on her.
Old May 3, 2017 | 04:09 PM
  #44
08VRSS's Avatar
Oh btw my firewall needed some love for the s257 to fit nicely, was getting some vibrations from the compressor hoisin in the firewall, might want to check yours tom. It drive me nuts thinking something broke
that s257 is quite different coming ffrom a zfr, I actually love the slow spool and the LDK sounds wicked, way different than the old lnf as far as tone in the exhaust.
Old May 3, 2017 | 05:27 PM
  #45
tomj77's Avatar
I checked mine, sites the same as it did with zfr. Have about 1/4 inch space
Old May 3, 2017 | 08:21 PM
  #46
tomj77's Avatar
True, and granted, I'm probably going a bit overboard with AND rerouting the oil and coolant lines, AND heat wrapping them AND heat wrapping the exhaust pipes and turbo and down pipe but once you write off an engine due to a cooked 30 dollar oil feed line you get a little nervous
ANyway, this is what I was talking about (not my picture)
I made this work with ldk I used a 90 degree fitting on the block port and ran along and under coolant hose and up around compressor and another 90 degree fitting on turbo. Worked great, much more comfortable with this way
Old May 4, 2017 | 10:38 AM
  #47
08VRSS's Avatar
I agree that looks much better. Another issue I've found since breaking it in and driving it now is that the cam tables absolutely had to be tuned. I at first used the stock tables for initial driving but it had this terrible engine shutter at around 12% throttle, 2500rpms and low loads, the idle was a little "off" feeling and just generally sucked at low load driving.
i pulled the plugs and they looked great, so I scratched my head. I remember I hated the stock cam tables bc of some weird issues before the swap too.
After hearing back from Ryan at ZZP that it's ok to tune the cam tables with the stage 2 cams, I loaded my cam tables I use on the tune and idle is smooth as silk, all shuttering is gone and it's a pleasure to drive now on any load, boost also comes in faster for sure now too.
How is yours running Tom?
Old May 4, 2017 | 10:45 AM
  #48
cw383's Avatar
Do you think its the turbo that accounts for the sound change in your LDK? Mine sounds about the same, but I have a 7163
Old May 4, 2017 | 11:28 AM
  #49
tomj77's Avatar
Well haven't driven yet but on cold start it idles like crap for 30 seconds then it sounds great. When I rev it half the time it revs , half the time it refuses too, but I'm also not tuned yet so will have to see once my brakes get here and I get it on the road
Old May 4, 2017 | 11:29 AM
  #50
08VRSS's Avatar
I'd probably guess more than likely the cams mostly, along with the turbo changed the sound. The s257 has a very nice subtle spool up sound as well, love it.
And Tom, thats the other problem i had too, a small rev felt terrible like it was missing but isn't actually, cam tables my man. And if you have cat warmup enabled, then yeah it will start and idle like crap. Mine is disabled and tuned out.
I'll drag out the gopro setup and make some videos soon.
