LDK build thread, version 2.0
Old Jun 8, 2017 | 05:35 PM
  #101
08VRSS's Avatar
Full pulls on how many psi, I can do full pulls too just not over 23psi lol.
If it doesn't work out i'll go with a KY stage 5, which is just like the southbend.
got around to taking apart the LNF finally started. Zfr off to be cleaned up and sold as a kit. And the old reliable ky stage 3 beast:
Old Jun 8, 2017 | 05:38 PM
  #102
KMO43's Avatar
Up to 30psi
Old Jun 8, 2017 | 09:32 PM
  #103
08VRSS's Avatar
After 1,400ish miles, I tried 24psi today. 3rd gear held all the way to redline, hit 4th gear and slipped away. I'm talking to James right now to exchange it for a stage 5 hopefully. I'm only putting like 11deg timing into the tune, it's flowing around 45lb/min of air which is great for such low boost, but that shouldn't be a lot of torque on 93. It definitely won't handle e47 torque. But the car felt great minus the slipping.....
So probably a pressure plate self adjustment issue on my particular kit or clamping force issue. Most likely going to have to come out..... I am not looking forward to this again..... I'll keep updated.
Old Jun 8, 2017 | 09:40 PM
  #104
63 Nova SS's Avatar
Sadly I have heard of this before. I haven't heard a ton of bad stuff about the south bend or omiotecs favorite-spec3+
Old Jun 8, 2017 | 11:01 PM
  #105
08VRSS's Avatar
Yeah it seems random, as my stage 3 has the exact same pressure plate. You can see how far it is adjusted too, the stage 4+ plate I got just had an issue. It's an LUK plate, just increased clamp force, so it may have been the plate manufacturer error not KY.
Ill go go for the stage 5 if they let me:
KY Stage 5
Old Jun 9, 2017 | 09:09 AM
  #106
royce777's Avatar
How many miles of not boost did you do for the clutch break in? When I did my LDK swap I put in a south bend stage four clutch. I did 1,500 not boost and baby the **** out of the car. Mine grabs great and has been holding great for 12k miles.
Old Jun 9, 2017 | 10:51 AM
  #107
08VRSS's Avatar
500 miles easy, 500 regular driving, and about 400 now of easy again.
Funny thing is, I said F it this morning and turned it up to 27 psi, and it held, but not making any premature hoorays yet.
Old Jun 9, 2017 | 01:44 PM
  #108
T-Man's Avatar
I'm going a full 1K miles on this bad boy before I do anything crazy. I've done my best to keep RPMs low and shifting as often as possible + rev match downshifting.
I hope the clutch continues to hold for you 08VRSS
Old Jun 9, 2017 | 07:56 PM
  #109
08VRSS's Avatar
I beat the crap out of the car coming home from work on the highway. 27psi of boost, car feels much faster than on the zfr and smooth as butter coming into boost, 2nd gear is kinda violent though when boost hits lol. Not once did it slip in 2nd 3rd or 4th. I think it's finally grabbing now, just needed a ton of load maybe. Fingers crossed it holds now. Red and green lines in top row are mph and rpm.
James had mentioned it's all about the load you put on it.
Old Jun 11, 2017 | 09:29 PM
  #110
tomj77's Avatar
2nd is completely useless. 30 psi and I spin so bad I hit rev limit almost right away
Old Jun 12, 2017 | 06:11 AM
  #111
63 Nova SS's Avatar
Even with good tires? That's a lot of power trying to put down at lower speed.
Old Jun 12, 2017 | 11:00 AM
  #112
08VRSS's Avatar
Tom, you know e47 is going to be completely ridiculous LOL
I scared someone so bad with a second gear pull bc of the open wastegate, i got the finger and horn on Friday. I just waved
Old Jun 12, 2017 | 12:15 PM
  #113
T-Man's Avatar
Looking good man! Happy to hear she's holding. I hope mine holds when the time comes because my WR3 hits hard AF (vacuum-21psi in .64 seconds) and I may need to neuter it a bit.
Are your cams corrected on your scanner, or? Values look interesting...
Old Jun 12, 2017 | 08:02 PM
  #114
08VRSS's Avatar
THose aren't the values you're thinking of, in fact I need to change that, thanks for the catch, I do not run standard cam tables though.
28psi today and seems to be holding, hopefully it's good.😬
e47 with a ton of torque may be a different story though.😳
Old Jun 12, 2017 | 09:39 PM
  #115
tomj77's Avatar
Haven't tried good tires yet lol just got em back today
Old Jun 12, 2017 | 09:40 PM
  #116
tomj77's Avatar
I wish I had some
Old Jun 14, 2017 | 11:12 AM
  #117
08VRSS's Avatar
SO heres whats happening.....
1,700 miles on it boosting 28psi (30psi just slips) on 93 octane. Clutch will slip for a sec and then hold....or just slip completely in 3rd and 4th.
I called Chris, the owner of KY Clutch. He wants to build me a custom clutch setup based on a stage 5 pressure plate and ceramic pucked disk to hold anything i can throw at it.... He said he'll start building it now and call him back in two days and he'll ship it to me with a return label to ship back the 4+....
Even though I have to swap it out, I'd say thats awesome for them to stand behind their product like that. Chris and James have been very helpful through this.
So thats whats happening. Chris said that the full face for some reason (most likely a pressure plate auto adjustment failure) just is not grippin, either i have too much low end torque, which i doubt, or too quick of a spool on the turbo. I think its just a full face clutch disk doesn't have the surface area needed to hold the kind of power I'm wanting out of it.
I hope T-man's 4+ is good as they haven't had any issues with the 4+ thus far. Only time will tell, I hope it works better for you than me, bc i feel terrible recommending it before when this happens.
Old Jun 14, 2017 | 06:47 PM
  #118
tomj77's Avatar
Well my South bend stage 4+ is holding strong on 30psi . I'm at 13 degrees timing so far and its not giving me any issue.
Old Jun 16, 2017 | 11:01 AM
  #119
08VRSS's Avatar
Well just got off the phone with Chris, owner of ky (really great guy BTW). Hes sending me today a 6 puck ceramic disk (similar to stage 3 which I've had) but with a custom made pressure plate usually used on stage 5 setups. He said it should be good for mid 500s torque.
Looking forward (not really lol) to getting it in there next weekend now so i can finally switch to E47 and make some big power.
Old Jun 17, 2017 | 10:33 AM
  #120
63 Nova SS's Avatar
Nice that they are wanting to help. I hope it holds. Is there really that much more contact with a 6 puck verses full faced? Or is it the clutch surface material?
Old Jun 18, 2017 | 06:35 PM
  #121
08VRSS's Avatar
Mathematically it does, there's more pressure per square inch in a pucked clutch than a full face one.
Ill upload pics when it gets here, installing in next weekend. Then break in all over again.
Old Jun 18, 2017 | 10:02 PM
  #122
63 Nova SS's Avatar
Figured there would be more pressure, but I just figured you had more contact with a full faced clutch. Makes sense though. If you use the same pressure on the pp.
Old Jun 19, 2017 | 05:38 PM
  #123
08VRSS's Avatar
Yeah i was kinda skeptical of the whole full face disk idea. Even TTR said they decided not to do it bc it wouldn't hold the tq. In a milder setup it would be great, the pedal feel is prefect and I really don't want to give up the wonderful driveability but..... because race car.
I could see this 4+ i have now holding maybe 25psi on a mild 93 octane tune on a S257, not more than that though.
I think this custom one they're sending me will be a slightly higher clamping force than most other ones they offer, coupled with the 6 puck ceramic disk. They said it will definitely hold mid 500s tq. I hope it doesn't have the old high pedal release the stage 3 did but oh well, i drove it daily for like 3 years. The pedal may be heavier too but thats also expected. I drove my T56 heavy clutches, I know what heavy is lol.
Old Jun 20, 2017 | 12:22 PM
  #124
08VRSS's Avatar
Going to experiment a bit with a hallman evolution rx, and maybe give my hybrid ebc/mbc idea a shot, worked great on previous builds and I like trying out stuff.
Old Jun 21, 2017 | 02:26 PM
  #125
08VRSS's Avatar
Replacement clutch is here, stage 5 pressure plate with 6 puck ceramic disk. Compared side by side with my old stage 3 pressure plate, the fingers on the pressure plate are way higher for more clamping force. Friday I'm gonna install it, hopefully everything goes smoothly.
Stage Frankenstein on left, stage 3 on right.
