LNF Throttle Body Swap Testing
Old 05-19-2009, 12:31 AM
  #51
Mazdaboi318's Avatar
This is WONDERFUL
Old 05-19-2009, 12:59 AM
  #52
EthensCobalt's Avatar
wow ..........
Old 05-19-2009, 05:36 AM
  #53
OneCOLDBIZL272's Avatar
Originally Posted by 1badBlueberrySC
THAT WAS NOT THE STOCK TURBO! CHeck their other thread people... this turbo runs out of breath well before 400ft/lbs
will my numbers are real. for tqr 394 316 hp, stock turbo, parts are ported but its still a stock turbo. hate to break it to ya. i will push higher number soon when i go from a mild tune to agressive and can do more tuning when my wideband arrives.
Old 05-19-2009, 07:26 AM
  #54
boostking's Avatar
I didn't spike mine that high but it was seeing 380wtq with clamps. I had no problems on the dyno but once at the track the car would throw an underboost code. My map sensor took a sh*t with those clamps on so not sure if it was them or just junk gm sensors
Old 05-19-2009, 08:15 AM
  #55
Terminator2's Avatar
Originally Posted by Matt M
We pulled the motor to put in the clutch, replace the head, and swap back to the stock turbo.
Swapping the head is a pretty solid days work if you take your time and double check everything.
We don't have DALs with the manual boost controller. We will get the boost leveled out for running this car on the street or at the track. For now, we are just pushing for higher numbers to see how everything responds.
I put the stock intake and TB back on after a few pulls today. After a few more pulls, we dyno'd again with the boost controller bumped up a little and going WOT by 30mph. Max boost was 29psi and torque hit 428 ft lbs. Here's a couple pulls starting at different RPMs to show how the boost eventually fades to the same level regardless of how the pull starts.
Oh, I thought you were using the MBC with just your big turbo setup. My bad. I dont think the stock maps like seeing that much pressure do they?
Old 05-19-2009, 09:09 AM
  #56
Matt M's Avatar
They don't see it with the regulators in place.
Old 05-19-2009, 09:24 AM
  #57
No wonder no limp mode this time. I wonder how long the turbo can take those shaft speeds. You are making more torque now with the stock turbo that you were making with your big turbo last time ( stock head though before but still). No traction when it wheels up I bet.
Old 05-19-2009, 09:32 AM
  #58
I bet that turbo is making some NOISE now!
Old 05-19-2009, 09:53 AM
  #59
Yep it gets louder as you crank up the boost.
Old 05-19-2009, 09:59 AM
  #60
i am still wondering how much a tubro swap upgrade kit will run!
Old 05-19-2009, 10:26 AM
  #61
Depends. Anywhere from $2000-4000 usually.
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
SlowSaturn
09-28-2015 11:03 AM
Adiaz1ss
09-26-2015 11:51 PM
09-26-2015 06:44 PM
Quick Reply: LNF Throttle Body Swap Testing
