May have solved 100% E85 on LNF puzzle
Old Mar 21, 2011 | 02:51 PM
  #426
MS3 2 SSTC's Avatar
Originally Posted by drewbroo
I am running the TF E85 tune now. Happy to report no clutch slip, and hauling ****
Did you contact Vince for the tune? I want the E85 tune as well.. I see you have an 09, is it out yet?
Old Mar 21, 2011 | 02:52 PM
  #427
drewbroo's Avatar
Vince is now doing 09's
Old Mar 21, 2011 | 02:53 PM
  #428
MS3 2 SSTC's Avatar
Let me contact him!! Was there a charge for it? I will pay if needed.
Old Mar 21, 2011 | 02:58 PM
  #429
drewbroo's Avatar
there is an upgrade fee, (its not much) contact him for pricing
Old Mar 21, 2011 | 03:00 PM
  #430
mongorat427's Avatar
I just got my Cryoed 4.45 gears and LSD back. Now the fun begins. Putting it back together
  #431
umrdyldo's Avatar
I think i'll give you guys some time on this tune. Sooo tempting though.
Old Mar 21, 2011 | 03:35 PM
  #432
shabodah's Avatar
So when is someone with direct injection going to crank up their compression?
Old Mar 21, 2011 | 04:24 PM
  #433
sponge14's Avatar
What would the point be?
Old Mar 21, 2011 | 04:30 PM
  #434
shabodah's Avatar
Making the engine run more efficient off of a better quality fuel?
Old Mar 21, 2011 | 04:43 PM
  #435
sponge14's Avatar
I understand on a naturally aspirated engine that you could up the compression to make more hp, but on a turbocharged motor would you not just up the boost pressure?
Old Mar 21, 2011 | 04:57 PM
  #436
umrdyldo's Avatar
Pretty much. As long as you aren't running your turbo past it's efficiency range.
Old Mar 21, 2011 | 05:11 PM
  #437
Matt M's Avatar
As far as running E85 and a stock turbo is concerned, raising the compression would be a great mod for the LNF. I'd go 10:1.
Old Mar 21, 2011 | 05:20 PM
  #438
drewbroo's Avatar
Boost pressure is a great way to increased "calculated dynamic compression," but the higher the boost the harder the turbo has to work. (On a low compression motor.) On a higher compression motor, a low boost engine will make the same or better HP than a High boost low compression motor. (using the same turbo.)
Old Mar 21, 2011 | 05:24 PM
  #439
MS3 2 SSTC's Avatar
Drewbroo... What psi is your tune set at?? I've contacted Vince and wasn't able to get a hold of him. I left him a message though.. I poured gas 2 days ago so I have 3/4 of a tank left so I'm in no rush to receive my E85 tune.
Old Mar 21, 2011 | 05:27 PM
  #440
Matt M's Avatar
Yup. Any time you can run the turbo in a more efficient range by lowering the boost and raising compression, there are gains to be had. In the case of a larger turbo where there is a lot more boost/airflow to be had without maxing the turbo, then less compression and more boost will result in more hp.
Old Mar 21, 2011 | 05:34 PM
  #441
drewbroo's Avatar
22-23PSI tune. Email you will get better results. Hes very busy with all the new orders for E85 tunes, so please be patient. vince@trifectaperformance.com is his email
Old Mar 21, 2011 | 06:10 PM
  #442
Iam Broke's Avatar
3-21 Update.... My 2400 psi file popped a P0087 Low Fuel Rail Pressure CEL in a 3rd gear pull tonight. Inj % went through the roof as did STFT's trying to get enough fuel in there. I think too much pressure throws the HPFP off it's curve but I have no proof other than my feeble results. Chicken or the egg kinda thing, which came first?
Loaded the 2200 psi layer file for the way home but it'll be raining by then.
Interested to see other peoples results....
Old Mar 21, 2011 | 07:50 PM
  #443
Turbo'dSS's Avatar
So is the E85 running fine with no codes on the 2200psi?? im just trying to gain as much info as i can before i got get my E85 tune on the 2nd of April. lol!
Old Mar 21, 2011 | 07:54 PM
  #444
Iam Broke's Avatar
No codes but injector % duty is pushing the limit on my LNF. I'll back the boost down to 22 psi if need be. Still testing.... need BYT's 'balt in on this testing too.
Old Mar 21, 2011 | 07:57 PM
  #445
Turbo'dSS's Avatar
Hmmm... well i ordered a trifecta cable so i can datalog, and im having andrew (Drewbroo) tune me on the second. Hopefully hell show me some tips and tricks with the trifecta program so i can kinda see what you guys are talking about. lol!
Old Mar 21, 2011 | 08:12 PM
  #446
09CobaltSS1's Avatar
You won't see a thing in the Trifecta datalogs. No one but Vince can view them, so there are no tricks a tips to learn
Old Mar 21, 2011 | 08:14 PM
  #447
Turbo'dSS's Avatar
Lol! who knows then? i just ordered the cable like i was told to do by drewbroo. lol!
Old Mar 21, 2011 | 08:18 PM
  #448
The cable is usefull in quite a few other applications other than tuning an LNF via trifecta, so maybe brebroo has something else planned? I guess you shall find out..
Old Mar 21, 2011 | 08:20 PM
  #449
Turbo'dSS's Avatar
yeah who knows? its the Tactrix cable. i just do what im told since im pretty clueless when it comes to tuning. lol! If im shown how to do something i can do it but if im told how to do it its a lil more complicated. lol!
Old Mar 21, 2011 | 08:35 PM
  #450
RyRidesMotox's Avatar
I'm right with you there. When learning how to do carbs... it only took one time of showing me. Computers are way too complex for me at this point... which is why people like Vince are around to figure this **** out for us and make it as easy as the click of a mouse.
