May have solved 100% E85 on LNF puzzle
There are a group of students at a university doing this, mostly inline with the findings from the Delphi paper on E85 and to study economy. I think they are running something like 12:1 or something like that.
ahhhhh!!! lmfao! gotcha now! lol! yeah that would be great to be able to do! lol!
Regardless, if you're looking for driveability, and not just peak horsepower, raising the LNF's compression seems to me to be the next step. I'm still confused about the fact that GM thought it was ok to run 9.5:1 compression on a supercharged, port injection engine, but dropped down to 9.2:1 on a direct injection, turbocharged car. There is no reason those numbers shouldn't have been reversed. At first I thought that GM was having a problem tuning to higher compression, or that the piston design was preventing them from raising it, but they are running 11.4:1 on the LAF with no issue. And considering both engines are designed for the "cat-****" that passes as 91 octane gaoline here in the states, it only seems reasonable both could do even better with a better blend of fuel.
PS- Mazda's new Sky engine runs 14:1 compression in Europe & Japan, but our fuel here is so bad, they are dropping it to 12:1 to run off it here in the States.
I agree with your disagreement
Case being K20 + 8PSI is more powerful than an LNF or LSJ + 8 PSI on the same turbo.
Built high comp K20 + 20 PSI > Built low comp LNF or LSJ or low compression K20 on the same turbo with same PSI level.
its all limited by the strength of the internals.
powerband is also better on a high comp low boost engine
If we were talking strictly on pump gas, your numbers work in your favor.
If we are comparing high boost and low boost engines with the same turbo, we are not tuning to the strengths of each build.
But, I'd like to see a good comparison of 2k-4k rpms betweent these builds when E85 or E50 was the fuel. I have no doubt that above 4-5k the higher boost engines make more power, I'm simply doubting the low to midrange.
Those numbers prove my case, not his... ?
Wow awesome work Vince. I just read every last word of this thread lol. I'm hoping some big turbo guys step in to test the earlier injection start on E10. I feel much better about starting the injection earlier than running 2800+PSI fuel pressure.
