Meth is up and running!
Old May 6, 2011 | 01:45 PM
  #51
Iam Broke's Avatar
New 'ON' LED arrived from superbrightleds.com, 5mm black bolt in green. Sits high enough that I can see it in my line of sight now and it's weatherproof. Car is dirty again. lol.
Old May 6, 2011 | 01:48 PM
  #52
Gremlin85's Avatar
No better way to test it than to wash the car
Old May 6, 2011 | 01:59 PM
  #53
AcesNEights's Avatar
What IAT2's are you seeing? Mine seem kind of high for meth. But I gotta look at previous logs to compare before and after.
Old May 6, 2011 | 02:03 PM
  #54
Iam Broke's Avatar
Tomorrow. Gotta cut the lawn today.
Old May 6, 2011 | 02:04 PM
  #55
Iam Broke's Avatar
Mine stay flat now instead of climbing a degree or 3, but I have the ZZP intercooler on it.
I was expecting more drop as well, but with the nozzle so close to the TB, it may be doing it's job in the cyls more than the intake.
Edit: I just realized I'm sprain' after the IAT2 sensor, I thought it was the one in the intake mani. No wonder I don't see a temp drop. lol.
Old May 6, 2011 | 02:06 PM
  #56
09BlueBaltSS's Avatar
Need to look at egt's
Old May 6, 2011 | 02:40 PM
  #57
Iam Broke's Avatar
Yep, too bad ours are estimated in the ECU.
Old May 6, 2011 | 02:46 PM
  #58
poo
Old May 6, 2011 | 03:05 PM
  #59
PrincessTurbo's Avatar
I got a 4.9 60-100 the other day when I blew my fuse for the pump. Didnt spray at all, and had about 4* KR up top....But 20*+ timing is nice tho lol
Thats what E's for
Old May 6, 2011 | 03:13 PM
  #60
DVSk8er's Avatar
any interest in a progressive controller have one for sale for cheap
Old May 6, 2011 | 04:24 PM
  #61
Gremlin85's Avatar
I'm hoping to go home to a package on my door step... I need MMMMMEEEETTTHHH!
Old May 6, 2011 | 07:50 PM
  #62
boostking's Avatar
I talked to Rodney when he moved to col. ohio and I believe I bought the first kit for a cobalt from him. he is a very nice guy to work with. EGT gauge is where its at!!!
Old May 6, 2011 | 08:22 PM
  #63
slowstang's Avatar
I wired up the controller and activation light tonight. The meth kit works now I just need to tap the charge pipe and it's complete!
Old May 6, 2011 | 08:28 PM
  #64
Gremlin85's Avatar
Where abouts in the charge pipe are you planning to tap it?
Old May 6, 2011 | 08:33 PM
  #65
slowstang's Avatar
I was thinking about tapping it just before the bend that goes up to the throttle body. My tuner wants to see the nozzle around 6" before the IAT2 sensor.
Old May 6, 2011 | 09:25 PM
  #66
Thats where I put mine, right before the bend.
Old May 6, 2011 | 10:56 PM
  #67
Gremlin85's Avatar
Once I start installing mine, I'll decide exactly where it's going.
First thought was right after the Intercooler, but I too am leaning more towards right before the bend up to the TB.
Old May 7, 2011 | 12:57 AM
  #68
ryansalazan's Avatar
id just installed mine and i like it alot bumping up to a 50/50 mix tomorrow! i mounted my nozzle on the piping exactly 8 inches before the throttle body which on the hahn charged piping landed me right about the middle of the bend.
Old May 7, 2011 | 11:14 AM
  #69
Iam Broke's Avatar
Nozzle moved
Woke up early ( It's a bitch getting old!) so I marked the ZZP lower CP where I wanted the nozzle located, drilled & tapped, & reinstalled the nozzle about 7or 8" in front of the IAT2 sensor in the bend of the CP. Plugged the previous location in the MAF block off plate with a stainless pipe plug.
Now the ECU can see a closer to actual intake charge temp. IDK why I thought the IAT2 was in the intake mani, I know better from splicing the sensor wiring. Brain fart.
Old May 7, 2011 | 01:44 PM
  #70
haha nice looks good bro! thats exactly where i put my meth nozzle. right at the bend its been good so far but then again ive only had it up and running for two days now haha
Old May 7, 2011 | 03:00 PM
  #71
Thought the rule of thumb was something like no more than 10" away from the TB because you want the mixture to still be evaporating as its entering the cylinder.
Old May 7, 2011 | 03:52 PM
  #72
Iam Broke's Avatar
According to the AIS website, if it is too far away, the cooling effects in the cyl can be diminished. Life is a compromise. I wanted it to be seen by the IAT2 sensor at least. AIS wants it close to the TB.
Old May 7, 2011 | 04:05 PM
  #73
doesnt the meth cause the ait2 to fail after a while
Old May 7, 2011 | 06:34 PM
  #74
Iam Broke's Avatar
We'll see!
Old May 7, 2011 | 09:40 PM
  #75
Got my 4.5 60-100 time today! Still dialing in my fuel trims too and still got a lil more timing to add in!
