P2187 &Loss of boost HELP!
Old Jun 29, 2009 | 03:42 AM
MEGAS's Avatar
Hello,
it's been a couple of months now that a sudden loss of boost happens without CEL.
After some miles boost is up again.
Yesterday i lost boost (only 80kpa)and after some miles CEL came up...P2187 !
I erased it with a dashawck and boost is fine after that ,untill i drove some miles and then again loss of boost(safe/limp mode on?)and again CEL !!
I took it to dealer..!
Any ideas what might be the problem..?
exhaust leak?
purge solenoid valve?
MAF/MAP related?
else?
Thank you in advance.
Car is 2007 opel GT same LNF engine with GXP/REDLINE!Yes it's moded with solo downpipe/catback and tune from EDS/germany.
Old Jun 29, 2009 | 11:38 AM
red2001ss's Avatar
I've got that before in mine, only after the aftermarket stuff went on. THe 2187 will limit the boost to like 6-7psi and not always throw a code. I just use my Dashhawk and scan for codes periodically and clear as neccessary. Other than that no issues. The code has something to do with running to lean at Idle, I'm thinking the MAF or MAP.
Old Jun 29, 2009 | 04:09 PM
cardelino18's Avatar
where can i get that dashhack? i have the same problem... i think...sometime it just does not boost at all
Old Jun 29, 2009 | 04:14 PM
red2001ss's Avatar
http://www.dashhawk.com/
Or you can search eBay for them, sometimes you can get them Cheaper like I did.
If your still running stock, I'd take it back to the dealer and have them check it out too. Could have a bad sensor or something. I'd also check and see if you have any loose tubing connections.
Old Jun 29, 2009 | 04:25 PM
Bad05SS's Avatar
i wish i could get one two of my friends have one none of the ss/sc are supported it sucks!!!
Old Jun 29, 2009 | 05:36 PM
red2001ss's Avatar
Just cause it's not on that list, doesn't mean that it won't work. However if the SS/SC's aren't CAN OBDII, then no it won't work.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
