People with the S1 cams, chime in!
I have tuned a couple cars with the cams. One car had thier pcm flashed for the cams.... I dont mean to bash but dang... I have no idea what they were thinking with thier tuning here. Everything on that car seemed backwards causing massive boost spikes over 30psi, 5-8*kr in daily driving under 3000rpms "thats the hesitant feeling your talking about" ITS KNOCKING!, Maf was maxed out adding as much fuel as possible, and I have no idea what they did with idle.... it idled so bad that we thought the cam timing was off majorly and tore the timing cover and valve cover back off to check. Ended up just throwing that tune away and starting fresh.
I'd like to hear the details on this. (If the previous tune was done by zzp.) Feel free to tell me who's car this was and what mods he had. If you don't want to post it here, then please PM it to me. These situations nearly always end up full of surprises when investigated closer. I'm sure this case will be no different.
This is exactly what I was talking about when I stated that any time someone's local tuner makes claims of the zzp base file being complete garbage and not able to make the car run right at all, there is always a bunch or surprises waiting to be brought out. Unfortunately, I was contacted zero times during the tuning process. When that happens, I have to believe that there was no plan to actually work with ZZP on the tune. In that case, it is the customer's choice and there isn't much I can do to change that. However, I can call BS on the claim that the ZZP file was the issue. The real issue was a lack of communication about changing key components of a build that render a previous ecm file useless.
Don't take it personally. It is not meant to discredit your tuning ability. It is meant to drive it into people heads that there is almost always a reason when one of these cars is not running right, and it is typically not because ZZP doesn't know how to tune. It is usually a result of faulty components, install issues, miscommunication, or a combination of these.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
