People with the S1 cams, chime in!
Old May 14, 2012 | 02:39 PM
  #76
Matt M's Avatar
Originally Posted by silverbullet08
I have tuned a couple cars with the cams. One car had thier pcm flashed for the cams.... I dont mean to bash but dang... I have no idea what they were thinking with thier tuning here. Everything on that car seemed backwards causing massive boost spikes over 30psi, 5-8*kr in daily driving under 3000rpms "thats the hesitant feeling your talking about" ITS KNOCKING!, Maf was maxed out adding as much fuel as possible, and I have no idea what they did with idle.... it idled so bad that we thought the cam timing was off majorly and tore the timing cover and valve cover back off to check. Ended up just throwing that tune away and starting fresh.
Originally Posted by Matt M
I'd like to hear the details on this. (If the previous tune was done by zzp.) Feel free to tell me who's car this was and what mods he had. If you don't want to post it here, then please PM it to me. These situations nearly always end up full of surprises when investigated closer. I'm sure this case will be no different.
As it turns out, the OP was running an ecm file set up for gas, but with E85 in the tank. He also stated that he had a custom intake and draw-through MAF and was told that he would have to fine tune the MAF chart. He later purchased a lower charge tube and set up the MAF blow-through.
This is exactly what I was talking about when I stated that any time someone's local tuner makes claims of the zzp base file being complete garbage and not able to make the car run right at all, there is always a bunch or surprises waiting to be brought out. Unfortunately, I was contacted zero times during the tuning process. When that happens, I have to believe that there was no plan to actually work with ZZP on the tune. In that case, it is the customer's choice and there isn't much I can do to change that. However, I can call BS on the claim that the ZZP file was the issue. The real issue was a lack of communication about changing key components of a build that render a previous ecm file useless.
Old May 14, 2012 | 04:38 PM
  #77
Kbbalt's Avatar
I got zero information from this thread...I was thinking about the s1 cams on my build which is basic bolts ons...
Old May 14, 2012 | 04:47 PM
  #78
silverbullet08's Avatar
I will try emailing you one more time then I will expose the entire truth about this issue.
Old May 14, 2012 | 05:07 PM
  #79
Matt M's Avatar
I'm not sure what you are saying. I have answered emails from you today. I am also not pointing fingers at you or anyone else. I am merely pointing out that once again when someone says that their ZZP LNF tune was garbage and not useable, there were other issues with the vehicle and/or different parts on the car than what was disclosed when the ecm was purchased. You asked me why the MAF chart would be set up one way when he bought the charge tube/MAF relocate from us, but there are two issues with that. One is that I can't be expected to look through customer's order history to find different parts that they might be running. More importantly, he purchased the charge tube/MAF relocate a month after he purchased the ECM. There were other things that caused similar issues as well. Now I know that as the tuner in this case, you have no way of knowing what the ECM was set up for and therefore you don't have a good starting point. I get that. i just want you to understand that we are in the same position when parts were changed and no one informed us or tried to work with us to adjust the tune.
Don't take it personally. It is not meant to discredit your tuning ability. It is meant to drive it into people heads that there is almost always a reason when one of these cars is not running right, and it is typically not because ZZP doesn't know how to tune. It is usually a result of faulty components, install issues, miscommunication, or a combination of these.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
