Possible Broken Turbo.... Rookie Mistake
This is the answer I was looking for. I have no problem tapping out larger holes on both the turbo and the bpv. I just want it fixed and i have access to the tools to do so I just wanted to know what the best fix was.
I saw that you did as well. I was hoping you of all people would reply. If heli-coil is too advanced for me I'll just tap it larger and use a bigger bolt.
Is same size standard bolt instead of metric, it's slightly bigger and when cleaning out the threads and putting it in it will modify the threads enough to work but not enough to be stripped again, and it will fit through the bpv hole without drilling it out
Iceberg
Sep 29, 2015 12:33 PM
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
