Possible Broken Turbo.... Rookie Mistake
Old Feb 10, 2016 | 01:54 PM
  #51
tomj77's Avatar
Originally Posted by no_ss
This is the answer I was looking for. I have no problem tapping out larger holes on both the turbo and the bpv. I just want it fixed and i have access to the tools to do so I just wanted to know what the best fix was.
I saw that you did as well. I was hoping you of all people would reply. If heli-coil is too advanced for me I'll just tap it larger and use a bigger bolt.
I didn't even tap a larger hole, I just ran same size tap as the bolt to clean it. The bolt I used must have been a standered bolt instead of metric , cause it went in tight, where as it didn't quite fit the other holes. Just don't over tighten again lol. That's the one thing I'm always paranoid about when I do something with my bpv.
Old Feb 10, 2016 | 01:56 PM
  #52
tomj77's Avatar
Yeah I didn't plan on threading the bpv. I was gonna just try and file it out to accept the larger bolt so it's still smooth.
Is same size standard bolt instead of metric, it's slightly bigger and when cleaning out the threads and putting it in it will modify the threads enough to work but not enough to be stripped again, and it will fit through the bpv hole without drilling it out
Old Feb 14, 2016 | 01:25 PM
  #53
no_ss's Avatar
Just to update this I got a heli coil in and out a longer bolt in another one because half of the heli coil was in the hole still and I didn't wanna drill on it. Holds fine.
Tupp
Sep 30, 2015 08:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
ashalle2
Sep 27, 2015 03:28 PM
