Some new stuff
Old Jun 25, 2013 | 02:36 PM
  #151
mrbelvedere's Avatar
looking good man you should look at exsoccer ewp setup its mega clean
Old Jun 25, 2013 | 02:37 PM
  #152
FF_ace's Avatar
im surprised I just came across this... good work man... I had euthanasia gasket match my IM
Old Jun 25, 2013 | 05:22 PM
  #153
cmiller8006's Avatar
I did mine lol.
Old Jun 25, 2013 | 05:23 PM
  #154
That's the best way to do it. But he got rid of the heater and all. I still have the heater.
Old Jun 25, 2013 | 05:59 PM
  #155
EXsoccer1921's Avatar
Yeah i'm not running a single part for hvac. it has it's pros and cons but overall i'd say it's worth it.
hurry up and get this thing together!!
Old Jun 25, 2013 | 06:07 PM
  #156
I don't have axles yet. And not sure when they'll be done.
Old Jun 25, 2013 | 07:19 PM
  #157
FF_ace's Avatar
did u gasket match the IM
Old Jun 25, 2013 | 07:25 PM
  #158
Yep, just took my time lol. Not perfect but the ports are all the same size.
Old Jun 25, 2013 | 07:27 PM
  #159
FF_ace's Avatar
nice man... euthanasia cuts the IM open p/p then welds it back together
Old Jun 25, 2013 | 10:51 PM
  #160
That's a good way to do it lol.
Old Jun 27, 2013 | 09:20 PM
  #161
skip_jones's Avatar
Shes got her car!
And it's probably faster!
Old Jun 28, 2013 | 12:54 PM
  #162
Haha
Old Jun 28, 2013 | 05:53 PM
  #163
blrt's Avatar
Can't wait for the dyno #...
Old Aug 13, 2013 | 11:57 PM
  #164
alright, had to re do the water pump, the way I had it was causing the pump to push coolant back up in the coolant tank. So here is the way it is now. I have a little left to do but looking to get it on the road tomorrow. Have to make sure there wont be any leaks and what not. And am going to make a new bracket to hold the water pump so it looks a little better, on to the pics.
Old Aug 14, 2013 | 12:01 AM
  #165
I forgot what our pm's consisted of honestly lol. Looks like you just split the coolant pipe. Was that your A plan or B plan?
Old Aug 14, 2013 | 12:07 AM
  #166
That's plan x prolly lol. But I talked with t jolley about his he did. And I was missing the concept of the ecotecs coolant system. The coolant constantly cycles throughout the motor and then once the coolant hits 180 the stat opens and pulls coolant through the motor. Where I had the pump at it was just pushing and not circulating anywhere but the coolant tank. even with the controller and the thermostat out, since I had the pump in the wrong spot it still wouldn't work. So now I don't even need the controller again and put the stat back in. Tomorrow will be the day.
Old Aug 14, 2013 | 12:09 AM
  #167
Essentially the davies craig pump is acting exactly like the stock pump now.
Old Aug 14, 2013 | 12:26 AM
  #168
FF_ace's Avatar
good work man
Old Aug 14, 2013 | 12:42 AM
  #169
Ah I got ya. With mine it just never let the engine get up to temperature. That's why we put the controller in there. It wouldn't heat up past about 153*.
Old Aug 14, 2013 | 01:07 AM
  #170
That's why I just put the stock thermostat back in. And I can get my 270 bucks back from the controller.
Originally Posted by FF_ace
good work man
Thanks man.
Last edited by cmiller8006; Aug 14, 2013 at 01:07 AM. Reason: Automerged Doublepost
Old Aug 14, 2013 | 01:10 AM
  #171
FF_ace's Avatar
is this a good option for a car that is a DD... or for only race cars
Old Aug 14, 2013 | 01:37 AM
  #172
I still plan to put 10,000 on it a year.
Old Aug 14, 2013 | 01:46 AM
  #173
Can it be driven on? Yes. I did it and will continue you to. Chris will do it much more. But I would stick with the oem pump if it's just going to be a daily driver.
Old Aug 14, 2013 | 06:58 AM
  #174
taintedred07's Avatar
Freakin awesome build man!
Old Aug 21, 2013 | 01:54 AM
  #175
raver0789's Avatar
Chis I have a few questions:
I just got an s259et Batmowheel myself like I had told you I was going to.
1) Did you go with an ATI balancer for your engine build?
2) What are your plans to rev this thing out to? 8k? I'd imagine with that 6262 the higher you rev the better. If you are reving it out high was there anything you did to this build to aid it in doing so? I'm going to have to rev mine as high as possible now too.
3) Who ported your head? Was it ZZP? What would your gains be from the ported head?
