Still getting knock...
Old Apr 19, 2011 | 12:54 AM
meckel's Avatar
Some people might remember me posting about getting knock randomly and mostly on tip in with my TC on my trifecta and stock tune and I now I get it everywhere... Vince still claims there is nothing wrong with my tune and I've tried regapping my plugs, switching to one step colder plugs, verifying coil packs, ect... and I always fill with 93 or 94 octane. Nothing has worked thus far and I have no idea what the issue is.
There is no rhyme or reason as to how the knock appears, it dominantly appears under load (of course) but It started today occuring on both my GMS1 tune and the Trifecta tune, randomly seeing as high as 4.8* of KR but more commonly 0.7* to 2.7* when it is there and this occurs at WOT but it even occurs at cruising speed an even sometimes under a small amount of throttle.
I have no idea what to do about this anymore. If anybody can point me in the right direction I'd really appreciate it, if not the car is either getting traded in or is getting put back to stock and sold.
Thanks in advance for not commenting 'get dyno tuned' or 'shouldn't have tuned your car in the first place.
Old Apr 19, 2011 | 01:03 AM
meckel's Avatar
I'll add that when at WOT the KR* can be maintained until I let off the trottle or will appear momentarily and disappear while still at WOT. It usually follows a 0.0*, 0.7*, 1.4*, 2.7*, 1.4*. 0.7*, 0.0* pattern when at WOT.
Old Apr 19, 2011 | 01:16 AM
evil 2.0's Avatar
being the pattern that it follows it might be false kr* it is a problem i had to deal with in my comp g and a pain in the back side to find . It happen to be a loose down pipe in my case .
Old Apr 19, 2011 | 02:10 AM
ronn's Avatar
I would second the *false knock* scenario. Change the knock sensors/check wiring on them and see what happens.
Old Apr 19, 2011 | 10:00 AM
meckel's Avatar
K, I'll check crate engine depot, hopefully this helps. Thanks.
Old Apr 19, 2011 | 10:22 AM
09CobaltSS1's Avatar
aside from a tune, what are you current mods?
Old Apr 19, 2011 | 10:23 AM
formula1rr's Avatar
What do your timing tables look like?
Old Apr 19, 2011 | 03:04 PM
094doorSS/TC's Avatar
since you said it happens on the gms1 why not clear out the trifecta tune take off the bolt ons and take it to the dealer?
Old Apr 19, 2011 | 07:41 PM
meckel's Avatar
I have a Catless DP, K&N SRI, Hahn CP. All have been tuned for. Ill check to see if the exhaust is leaking or if im getting some ping from any metal parts. Not sure at this point what It could be...
I have no access to view my timing tables, Im sure Vince wouldnt have my car running bad timing on the car. Like I said he viewed over a few logs and unless he's lying to me I think its ok.
My dealer wouldnt do warranty work on my car when it was stock, there is no way I could get away with that.
Old Apr 19, 2011 | 08:16 PM
tomj77's Avatar
at light throttle is normal for this car so i see, but my question is how are u reading ur knock? dashdaq or scan gauge or cel flash or what?
why wouldnt he do warrenty work on it when it was stock? he has to
Old Apr 19, 2011 | 08:51 PM
meckel's Avatar
Reading it with dual Aeroforce Interceptors. I had GMS1 installed at a dealership when I was out of town for work and then my local dealership claimed it was an aftermarket unwarrantied part so they voided my warranty.
Old Apr 19, 2011 | 08:56 PM
tomj77's Avatar
um, id fight that, cause gm clearly says it does not void ur warrenty.
Old Apr 19, 2011 | 08:59 PM
Souperman's Avatar
Yeah they cant void your warranty cause its a GM part. Def fight that
Old Apr 19, 2011 | 09:25 PM
meckel's Avatar
Yea, I did, it took 5 months to get my $400 back from repairing an install error when the kit was originally installed and to get them to take me off of some sort of list. No apologies about it either. The only other GM vehicle I'll ever buy is the Chevelle I might trade this one in on.
Old Apr 19, 2011 | 09:33 PM
tomj77's Avatar
u should have told them they lost ur business and that of everyone u know. and go to a diff dealer
Old Apr 19, 2011 | 11:17 PM
meckel's Avatar
I went to three different dealers, all of them refused to do the work under warranty including the one that originally installed the kit. I think they could care less about losing warranty work, but I was treated like garbage by every service manage and was told to stop conning the dealership into getting free work done.
Old Apr 20, 2011 | 12:04 AM
evil 2.0's Avatar
gm has hotlines for problems like this .do you know how much trouble you could get these places in?
Old Apr 20, 2011 | 06:57 PM
meckel's Avatar
I did I had a GM rep assigned to me that guaranteed that I'd get my money back, but I didn't get any of the funds from missing two weeks of work, driving back and forth to a dealership 3 hours away, etc... I'm still upset about it and I will never buy another GM daily driver.
Old Apr 20, 2011 | 07:03 PM
DoMiStIc_RuSh_06's Avatar
My car does the same thing, mostly when I'm into boost. I have a term tune and he is working with me to try an figure it out. The funny thing is, no matter how much he lowers or raises the timing, the knock doesn't change. I can see up to 5 degrees of knock but usually 2.2-3.7 degrees.
Old Apr 20, 2011 | 07:19 PM
meckel's Avatar
Please keep me updated and let me know if you figure it out, I'm going to go through the car this weekend and I'll post if I find anything that solves it or at least minimizes it.
Old Apr 20, 2011 | 07:26 PM
Well, right now my Kn Sri intake is hitting the firewall when the motor trqs back. Not sure it that's it but I'm gonna do some research on Friday.
W3RK'D
Aug 26, 2013 12:37 AM
seeyaass
Aug 28, 2012 11:31 AM
Frogstofall
Jan 11, 2012 01:21 AM
1_quick_balt
Dec 8, 2008 04:52 PM
brifriinc
Apr 16, 2007 07:52 PM
