Trifecta Tune
Old Feb 23, 2009 | 05:14 PM
  #151
FutureEcotecOwner's Avatar
Originally Posted by Terminator2
Is your car stock? If so he should be beating you if he runs low 13s.
Mustangs arent just like the SS/TC, but until you get them tuned, they dont run much faster than stock. You might knock off a couple tenths or add 10rwhp, but with a tune you can knock off .4-.5 tenths and add 25-30rwhp.
Actually, he has a video of him basically sitting right next to and eventually beating the GT by a little. They stopped the race at 140 ish. So I retract my previous statement about the GT being faster. I wonder what my TC would do to that mustang I have about 54 whp and 83 wtrq more than stock
From a roll I think my SS/TC would take my Mustang, but from a dig I would give it to my Mustang all day long.
Last edited by FutureEcotecOwner; Feb 23, 2009 at 05:14 PM. Reason: Automerged Doublepost
Old Feb 23, 2009 | 05:18 PM
  #152
MARIN007's Avatar
Can someone with the Trifecta tune please post a dyno sheet? I'd like to see the curves
Old Feb 23, 2009 | 05:22 PM
  #153
elecblue06's Avatar
Old Feb 23, 2009 | 06:17 PM
  #154
Cobaltss/TC's Avatar
^^^^Hey that looks like mine, there is a huge thread on that graph somewhere around here
Old Feb 23, 2009 | 06:19 PM
  #155
cmiller8006's Avatar
I was wondering with a tune if the torque starts to drop off at 5000 rpms is it a good thing to shirt at like 5000-5500 instead of redline.
Old Feb 23, 2009 | 06:22 PM
  #156
You got to remember torque is what gets you started but horsepower is what keeps you going, so it is ok cause the horsepower peaks in that area, so i shift at 6k
Old Feb 23, 2009 | 06:23 PM
  #157
elecblue06's Avatar
probably was i got it from hhrforums lol
just the first place i found it
Old Feb 23, 2009 | 06:25 PM
  #158
I was joking i know it is mine, just funny where people are finding it
Old Feb 23, 2009 | 06:36 PM
  #159
hows the stock clutch doing.
Old Feb 23, 2009 | 06:49 PM
  #160
its doing just fine, it just doesn't like hills when i am in 4th and floor it hahah
Old Feb 24, 2009 | 08:49 AM
  #161
Terminator2's Avatar
Dude, dont do that to your poor clutch. Unless you want to spent $1200 on a new clutch and flywheel.
Old Feb 24, 2009 | 10:17 AM
  #162
Are clutches and flywheels really that much for our car? I paid like $400-500 for a new clutch and flywheel on my Wifes 2000 Celica GTS a few years ago. Jesus Christ that is way too expensive.
Old Feb 24, 2009 | 10:33 AM
  #163
A spec stage 3+ clutch with an aluminum flywheel comes to around $1100. It is like $700 for the clutch alone.
Old Feb 24, 2009 | 10:40 AM
  #164
Damn that is alot!! Hopefully my clutch will hold up for awhile, LOL!
Old Feb 24, 2009 | 10:53 AM
  #165
It should if you take it easy most of the time. Do not use WOT in the higher gears in the lower revs you are asking for it to start slipping. If you do go WOT in third wait until at least 3000 RPM first. 4th-5th wait until above 3500RPM.
Old Feb 24, 2009 | 11:30 AM
  #166
eiuprtycntrl's Avatar
Can you buy a clutch without buying the flywheel? I want to keep the stock flywheel because a lighter one will cause the engine to rev faster and spin the tires more so I want to keep the sotck, heavier one.
Old Feb 24, 2009 | 11:32 AM
  #167
JPizzle's Avatar
Ah. No. It is not recommended at all!
Old Feb 24, 2009 | 11:37 AM
  #168
I have heard both stories. Some people have said that you have to change the flywheel when you change the clutch but others have said that you dont have to so I too am confused.
Old Feb 24, 2009 | 12:09 PM
  #169
me too
Old Feb 24, 2009 | 12:15 PM
  #170
MaxVQ35DE's Avatar
its been said that trifectas tunes run a bit leaner than other tuners? what gives?
Old Feb 24, 2009 | 12:31 PM
  #171
No it isn't people just didn't understand the difference between tuning a DI car and a port injected car
Old Feb 24, 2009 | 12:50 PM
  #172
spec says you can replace the clutch alone, its like 550 straight from them
so your tuned and have the stock clutch right, how is it doing. i was getting the trifecta tune then herd of the clutch problem if there are not many problems i will probally get the tune
Last edited by cmiller8006; Feb 24, 2009 at 12:50 PM. Reason: Automerged Doublepost
Old Feb 24, 2009 | 01:14 PM
  #173
Actaully, It runs richer than a typical tune for a TC is 12.8 -12.5 A/F. Trifecta is 12.4-11.8 A/F which is quite rich for a DI car but it is a lot safer than the stock tune which is stupid lean.
Old Feb 24, 2009 | 01:15 PM
  #174
^ true. stock tune sucks
Old Feb 24, 2009 | 01:27 PM
  #175
Definately, My car had 3* of knock with the stock tune, and that was with 93 octane in the tank inagine with 91 octane. The knock was between 3000 and 4500 RPM where the A/F was 15.7. That is a lean A/F for a forced induction car DI or not.
