Trifecta Tune
Old Feb 24, 2009 | 02:34 PM
  #176
cmiller8006's Avatar
i get alot of black soot from the tail pipe and have always been told that is rich and lean was where you dont get the soot. is this different in DI motors
Old Feb 24, 2009 | 02:38 PM
  #177
Terminator2's Avatar
All motors produce carbon soot. It is that a normal byproduct of the combustion process, but most cars do not have strait through mufflers like our cars do. Instead of all that carbon collecting in the muffler it shoots right out to the tail pipe. Even with as lean as the stock tune is it will still blacken the crap out of the tailpipe. Perfactly normal and nothing to worry about just messy to clean.
Old Feb 24, 2009 | 10:37 PM
  #178
Chandler's Avatar
Question
Originally Posted by Terminator2
Definately, My car had 3* of knock with the stock tune, and that was with 93 octane in the tank inagine with 91 octane. The knock was between 3000 and 4500 RPM where the A/F was 15.7. That is a lean A/F for a forced induction car DI or not.
How many times did you see this knock?
I am thinking that the ECU was still adjusting. If it was a new tank of gas and you did three runs back to back , not sure if it was long enough to compensate for the current conditions. If it was consistant on different days and gas then that would be different. Sometimes ghost knock will occur with stock tunes as well. The same could be applied to the AFR if it is not corrected yet.
si o no , amigo?
Old Feb 24, 2009 | 10:53 PM
  #179
eiuprtycntrl's Avatar
and whoever said you can buy the spec clutch for $550 straight from them where can you getting that from? Because it was over $600 on their forum
Old Feb 24, 2009 | 10:54 PM
  #180
Old Feb 25, 2009 | 08:43 AM
  #181
si o no , amigo?
3 pulls stock tune. It was not Ghost knock it was there for all three stock pulls. Car was driven down the hwy to the shop for about an hour so it was adjusted and warmed up. I did stop to top off the fuel tank about 3 gallons or so went in and I drove for 30 Min after that but that is not it trust me. The fuel just takes too long to get there after you go WOT so we made it come a little sooner and richened it up quite a bit and that took care of the knock. Loaded dynocom dyno that I used may have something to do with it too. Still should not knock like that
Old Feb 25, 2009 | 10:31 AM
  #182
FutureEcotecOwner's Avatar
spec says you can replace the clutch alone, its like 550 straight from them
so your tuned and have the stock clutch right, how is it doing. i was getting the trifecta tune then herd of the clutch problem if there are not many problems i will probally get the tune
As of now it has been holding up fine, no problems at all.
Old Feb 25, 2009 | 11:39 AM
  #183
Chandler's Avatar
according to http://www.zercustoms.com/news/Chevr...-SS-Turbo.html
The full torque seems to come on the the range that you have said. So I am thinking that with the DOHC and this aggressive torque goals from the factory to achieve this number so early in the power band might add the the leanancy of the tune. The above graph doesnt seem to indicate any knock in that range , but is obvious lean in the said area. It seems that with the type of turbo they chose that extra timing seems to get the turbo to spool faster and maybe create higher ext gases, hence the blow through muffler setup as well. I dyno'ed my car as well and had a similar graph in my AFR's. but no knock. So I am thinking that with the Alum block they feel that this is acceptable for them if they are going to warranty it .LOL I know that from my previous experience from tuning my cars that all the FI cars will have knock in consistant places, due to maybe casting errors, assembly, injector malfunctions, etc. , but all seem to stay within acceptable AFR's. All this to say that I think that this knock might not necessarily be detrimental, although not ideal , probably more enevitable.
I think that the load dyno is probably not the culprit , unless it was improperly calibrated , but I doubt that.
Old Feb 25, 2009 | 11:46 AM
  #184
The full torque seems to come on the the range that you have said. So I am thinking that with the DOHC and this aggressive torque goals from the factory to achieve this number so early in the power band might add the the leanancy of the tune. The above graph doesnt seem to indicate any knock in that range , but is obvious lean in the said area. It seems that with the type of turbo they chose that extra timing seems to get the turbo to spool faster and maybe create higher ext gases, hence the blow through muffler setup as well. I dyno'ed my car as well and had a similar graph in my AFR's. but no knock. So I am thinking that with the Alum block they feel that this is acceptable for them if they are going to warranty it .LOL I know that from my previous experience from tuning my cars that all the FI cars will have knock in consistant places, due to maybe casting errors, assembly, injector malfunctions, etc. , but all seem to stay within acceptable AFR's. All this to say that I think that this knock might necessarily be detrimental, although not ideal , probably more enevitable.
I am unsure as well but the timing advance on these cars is pretty conservative if you ask me. It is like 10* advance at WOT stock. I have mine advanced to 14* advance with no knock whatsoever. My A/F is richer than that tune on the bottom end though. The dyno was loaded to 8% because unloaded the car boosted only 14 psi stock instead of 16 psi.
Old Feb 25, 2009 | 02:37 PM
  #185
Chandler's Avatar
Did you happen to get a look at how much timing was at the range of knock on the stock tune? Is the TDC range the same in these DI cars as in regular FI?
Old Feb 25, 2009 | 02:50 PM
  #186
malachii's Avatar
It should if you take it easy most of the time. Do not use WOT in the higher gears in the lower revs you are asking for it to start slipping. If you do go WOT in third wait until at least 3000 RPM first. 4th-5th wait until above 3500RPM.
Hmm. I would have thought that the higher gears would cause the clutch more distress, but you seem to imply that the low gears are the bigger problem? I've never had to deal with clutch slip before, and will be getting a tune shortly, so I guess I should start learning how to deal with it...
Thanks, Mal.
Old Feb 25, 2009 | 03:02 PM
  #187
I went and looked it up the 557.00 was for a stage two clutch for a sc, and it was 619.00 for a stage three for the tc. my bad
Old Feb 25, 2009 | 05:35 PM
  #188
JPizzle's Avatar
Thanks, Mal.
No. The clutch would have more stress in higher gears at lower rpm's. That is what could cause the clutch to slip!
Old Feb 25, 2009 | 06:26 PM
  #189
blackrocky's Avatar
i just got my tune 2day and all i can say is wow!! other then the traction problem everything is good and no clutch slippage whatsoever. all props to everyone @ cia and trifecta!
Old Feb 25, 2009 | 06:48 PM
  #190
Cobaltss/TC's Avatar
Glad to hear it!
Old Feb 26, 2009 | 09:34 PM
  #191
DNewman's Avatar
I got my cable today and I am blown away by this tune. It was cake to use the software and install the tune. The car pulls so hard its unbelievable!
Old Feb 26, 2009 | 10:22 PM
  #192
Mazdaboi318's Avatar
You guys are getting me excited!
Old Feb 26, 2009 | 10:26 PM
  #193
blackrocky's Avatar
you should be! lol
Old Feb 26, 2009 | 10:27 PM
  #194
I wanna scare some people when they ride and i am sure this will do it lol!
Old Feb 26, 2009 | 10:35 PM
  #195
blackrocky's Avatar
it scares me sometimes lol
Old Feb 26, 2009 | 11:23 PM
  #196
cobaltss1969's Avatar
how do you install it???
Old Feb 27, 2009 | 12:40 AM
  #197
blackrocky's Avatar
plug up, load, and drive
Old Feb 27, 2009 | 04:35 AM
  #198
blownss06's Avatar
Did Anyone Just Use The Cable And Your Laptop For The Tune? If So Do You Data Log It At All And Send That Back To Vince So He Can Tweek It Out And Send You A Revised Tune Through Email.
Old Feb 27, 2009 | 07:31 AM
  #199
DNewman's Avatar
I used my laptop and cable, but I didn't datalog and send it back to vince. I am waiting until I get my downpipe and Cold Air Intake before I have him adjust it.
Old Mar 5, 2009 | 11:18 AM
  #200
WWWWWWWOOOOOOOOOOOOWWWWWWWWWWW !!!!!!! Just tuned it. easiest thing in the world and WOW does it pull boost up to 22, yes some slippage up front but this is amazing!!!! Thanks guys, just let me know where I can get the metal to replace the plastic on the turbo. Wow can't get over how easy and the incredible notice in hp and torque!!!!
